My EF At the Track
My Hatch on a Kind of a Shake Down run on new setup ran 13.1 @ 108mph.. So its getting there.
I only got two runs in.. First was 13.4.. Second was 13.1... I was still getting the Air Pressure Right in the Slicks and the shift points down again but its getting quicker.
Set up is in Sig.
Set up is in Sig.
looks like the guy before ran a red
nice times, was the track damp at all? it looks like you still have snow on the ground
Pulled alot of Timing Out.. Ran a couple Degree Cooler Plugs.. Wet Kit.. Larger Fuel Pump and 114 Octane Gas.. I have taken every precaution but if it breaks it breaks.. Time to Build it up then..
And it was near 70 degrees that day.
And its just a 75hp Shot. Not a ton.
it's good , but are you still spinning tires ?
my brother has the exact same car with a dohc zc - 75 shot , 13" slicks and he ran 13.1 @ 103 mph ..... (only chipped ecu , mitsu. eclipse fuel pump , homemade air intake, no passenger and rear seat)
That day i only got a couple runs in.. I was still trying to figure out the Tire Pressure and Launch Point. But I think they are a 22" Slick.
I am going back out to the Track this 19th for a 12 second pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">A healthy b16 will take a 75 shot without a hiccup.
Keep spraying.
Word life
Keep spraying.
</TD></TR></TABLE>Word life
The Rims on the Front are Forged Centerlines. Very Very Light. Pictures have also all been fixed now too.
And yes only a matter of figuring out the launch and 12's will be no problem. Plus when I ran that 13.1 I left off for a second because I was not used to the car hooking like that.
Stock Axles for now. Looking into Either Fidanza or Gator Axles.
Rims on the Rear. No Clue some old *** bronze Honda ones.
And I won't be out to the Track around here till April. Its not warming up at all.
LSVTEC 91 Civic
14
Apr 22, 2005 03:57 PM
b16_incarnate
16
Oct 23, 2002 01:36 PM
EVOCELICA
22
Aug 29, 2002 12:36 PM
