need urgent help
Old Mar 12, 2005 | 07:40 PM
89hbcivicguy's Avatar
Default need urgent help
hey guys i need to know one thing my cars running really rich.....and i was goin to hook a snap-on scan tool onto my car but i cant find the connector......no i was wondering.....where is this connector i know its under the carpet on the passenger side but where........NEED HELP ASAP!
Old Mar 12, 2005 | 07:41 PM
EL Vap133's Avatar
Default Re: need urgent help (89hbcivicguy)
What connector?
Old Mar 12, 2005 | 07:45 PM
Default Re: need urgent help (EL Vap133)
there should be a connector for the scan tool to hook up too
i know there is its been on one before but i didnt do it
Old Mar 12, 2005 | 07:46 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy &raquo;</TD></TR><TR><TD CLASS="quote">there should be a connector for the scan tool to hook up too
On a pre-OBD vehicle?
Old Mar 12, 2005 | 07:55 PM
trust me its there!
Old Mar 12, 2005 | 08:00 PM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
On a pre-OBD vehicle? </TD></TR></TABLE> i dont think there is on obd-0
Old Mar 12, 2005 | 08:02 PM
88crx-si's Avatar
sorry man..OBD0 cars do NOT have diagnostic ports for scan tools.
under the carpet on the passenger side is the ECU which has an LED. the LED blinks to show a code...thats pretty much it...
Old Mar 12, 2005 | 08:03 PM
Default Re: need urgent help (hatchinprogress)
YES THERE IS.......ITS BEEN HOOKED UP ON MY CAR BEFORE I JUST DIDNT HOOK IT UP......AND I CANT REMEMBER WHERE IT WENT.......THE SNAP ON SCAN TOOL READS ANY AND ALL COMPUTERS.....RIGHT BACK TO 1980!
IM APPRENTICEING FOR A MECHANIC I SHOULD KNOW.....
Old Mar 12, 2005 | 08:05 PM
mr. carpenter's Avatar
there is a blue plug that hangs under the dash. is that what you're talking about? if you're looking for ecu codes, they are flashed in the little diamond window on the ecu.
Old Mar 12, 2005 | 08:11 PM
Default Re: need urgent help (mr. carpenter)
i know.....that led doesnt help anything......it tells u the circuit but not the exact problem.....the snap on scanner will tell you whats wrong with it.............so u say its a blue plug.......where&gt;?????its supposed to be under the carpet
Old Mar 12, 2005 | 08:16 PM
under the glovebox door, close to the passenger side door. is the red led flashing? if so how many times. that light will tell you alot.
Old Mar 12, 2005 | 08:20 PM
its doesnt tell u ****.....i ahd that once....and it told my fuel ijection cicruit....and it was the ignitor not......an injector.....ignitor......that ECU is garbage......i jsut wanna know where the damn plug is
if u cant answer my question the stop replying
Old Mar 12, 2005 | 08:23 PM
Keebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy &raquo;</TD></TR><TR><TD CLASS="quote">YES THERE IS.......ITS BEEN HOOKED UP ON MY CAR BEFORE I JUST DIDNT HOOK IT UP......AND I CANT REMEMBER WHERE IT WENT.......THE SNAP ON SCAN TOOL READS ANY AND ALL COMPUTERS.....RIGHT BACK TO 1980!
If you truly are trying to be a mechanic, you should listen to what others are telling you. Yelling on a forum is not going to get you the desired results.
You have failed to give us any information about your vehicle. Year, make, model, swap (y/n) yadda yadda...
Try giving us more information to help you, and you will most likely get the answers you need. There are some very experienced people on this board, but we cant help you if you dont tell us all the needed info.
How do you know its running rich? What led you to that conclusion?
Old Mar 12, 2005 | 08:26 PM
Default Re: need urgent help (Keebler)
89 Honda civic DX 1.5L d15b2.......completely stock
the fact that it failed etest i hooked it up to a scope and the air/fuel ratio is 13.1.......the it should be 14.7
Old Mar 12, 2005 | 08:35 PM
bagpipe goatee's Avatar
I'm sorry, but when i completely rewired my car, it didn't have a port. maybe it can do all cars since 1980, but since there was no port required yet, it makes sense that some were manufactured with alternatives, i.e. a blinking l.e.d. if its been connected before, i don't know. good luck.
Old Mar 12, 2005 | 08:46 PM
88crx-si's Avatar
thats right! you SHOULD know. when you find one, let us know.
and theres no need to yell. its not like my first post said,
"THERE IS NO ******* PORT WHATSOEVER"
damn. just trying to help a guy out..
Old Mar 12, 2005 | 08:52 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (bagpipe goatee)
did your scan tool say "extensive wiring required" for pre-1992 cars?
Old Mar 12, 2005 | 09:01 PM
smoke07018's Avatar
the scan reader doesn't work on car before 96. unless you have a gm then they have special adapters. but for you car you will have to go to auto zone or some other store to check it out. it's a two prong tool for that. the code is display by the flashing of your check engine lite. hopefully this answers your ?
Old Mar 12, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy &raquo;</TD></TR><TR><TD CLASS="quote">its doesnt tell u ****.....i ahd that once....and it told my fuel ijection cicruit....and it was the ignitor not......an injector.....ignitor......that ECU is garbage......i jsut wanna know where the damn plug is
i answered your question. learn to spell. use complete sentences. make me stop replying.
Old Mar 13, 2005 | 04:34 AM
alright.....sorry i was in a bad mood last night....
like i said my car is and 89 civic dx with a 1.5L d15b2
one of the mechanics in town has had the snap-on scantool on my car before
thats how he found out the ignitor was shot in it....but now its running rich and i dont know why......i know it hooks up to my car but i cant remember where......i dont know if u have to unplug something to plug this in or what but i know it plugs into my car......if i find out where i will let you all know
Snap on scanners work on OBD-2 OBD-1 and OBD-0 computers
Old Mar 13, 2005 | 05:16 AM
sit220's Avatar
if u dont belive what everybody is saying then go and grab ur snap on scaner and press the button (the red one ) and select ur car and if the car has a plug the scanner should tell u
but of course ur car doent have a plug for obd0
the only plug i seen in a honda its the one for obd2 the one i use to do emission test
i think the only cars that had plugs since 80s were gm cars
Old Mar 13, 2005 | 05:19 AM
sit220's Avatar
Default Re: need urgent help (sit220)
one more thing
go and buy a helms manual and look how to read codes and what each code means
Old Mar 13, 2005 | 07:11 AM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy &raquo;</TD></TR><TR><TD CLASS="quote">Snap on scanners work on OBD-2 OBD-1 and OBD-0 computers</TD></TR></TABLE>
there is no such thing as obd0 its called pre obd because thats what it is. in the era before there was any standardization.
did you SEE this device hooked up to your car, or did he just tell you that to try to impress you.
because if he did indeed have that device hooked up to your car, then he tapped into the wires at the ECU like an APEXi system would, which is a ******* retarded thing to do.
just count the LED flashes, get the code, and fix the problem, with a helms manual. if you dont have a code then you need to follow the flow charts in the helms and you will find your problem. you could also swap in a newer D series if you want odb1 so badly.
i completley rewired 2 EF cars, from the tail lights to the front bumper signals, COMPLETLEY. there is no diagnostic port. ON TOP OF THAT this thread is useless waste of bandwidth because your title is a non descriptive piece of ****
"need urgent help" great.... now NO ONE can EVER search for it and use the information found here.... and stop being an *** to people.
MacDuff
Feb 6, 2008 03:54 AM
SiHater
Oct 26, 2006 01:01 PM
chase69
Honda Motorcycles
10
Dec 29, 2004 06:38 PM
RichieCB7
Nov 17, 2004 03:39 PM
Glai1628
Feb 15, 2004 01:47 PM
