Dyno results .
Old Mar 12, 2005 | 05:30 PM
Marlon88's Avatar
Default Dyno results .
Hello Honda people
The other day I went to a shop where they can dyno tune your car and I made an appontment and I went for some dyno runs, first run it dyno`d 204 flywheel horsepower then after some tuning with the fuel pressure regolator and with the timing it picked up 4hp now the final tune results were like this :
Max Power at the Flywheel : 208.0 @ 8606 rpms
Max Torque at the Flywheel : 134.7 Lbft @ 7204 rpms
What do you guys think ?? Good ?? Bad ??
What is the power at the wheels WHP ??
Thanks
Marlon
Old Mar 12, 2005 | 06:18 PM
fastfour's Avatar
Default Re: Dyno results . (Marlon88)
Assuming a 15% drivetrain loss:
176.8hp/114.5tq
Old Mar 12, 2005 | 07:08 PM
Bbasso's Avatar
How did they get flywheel results? did they take the motor out of your car or the tranny?
Old Mar 12, 2005 | 07:11 PM
an2ny888's Avatar
were the dyno runs made with the spoon ecu?
Old Mar 12, 2005 | 07:43 PM
vtec.dc2's Avatar
Default Re: Dyno results . (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">How did they get flywheel results? did they take the motor out of your car or the tranny?
it was more than likely estimated.. that and hp over there is btu or kw or whatever they measure in Europe for hp.. or is it torque?
Old Mar 15, 2005 | 04:50 PM
Marlon88's Avatar
Default Re: Dyno results . (vtec.dc2)
No it was just a normal Dyno that mesures BHP and torque , I don`t know much more about it , the graph that he gave me is mesured as flywheel horsepower .
The dyno runs were made with the Spoon Sports ECU and he tuned with the fuel pressure regolator and spark timing.
I will hook up my scanner and I will post the graph.
Are the numbers that I got good for the mods that I have !?
Old Mar 15, 2005 | 06:54 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 &raquo;</TD></TR><TR><TD CLASS="quote">The dyno runs were made with the Spoon Sports ECU and he tuned with the fuel pressure regolator and spark timing.
Are the numbers that I got good for the mods that I have !?</TD></TR></TABLE>
If those are the only two mods, then yes it sounds like a great number.
USDM ITR's stock dyno between 160-170 WHP, probably closer to 160.
Old Mar 16, 2005 | 12:52 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 &raquo;</TD></TR><TR><TD CLASS="quote">No it was just a normal Dyno that mesures BHP and torque , I don`t know much more about it , the graph that he gave me is mesured as flywheel horsepower .
dyno measures torque and hp is calculated from that.. if it dynoed at the wheels, and that would be where your car is driving on the rollers, then flywheel hp has been estimated.
Old Mar 17, 2005 | 09:26 AM
sylvain's Avatar
208HP is impossible on a stock car with just timing and Spoon ECU, the stock EUDM ITR are about 184-186HP (at the flywheel), so you can't gain 22HP with thoses mods. The max power rpm is not good too, the stock Pmax is at 7900-8000rpm and it's very difficult to go higher with our stock header.
Try an other dyno.
Old Mar 19, 2005 | 03:54 PM
Marlon88's Avatar
Default Re: Dyno results . (sylvain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sylvain &raquo;</TD></TR><TR><TD CLASS="quote">
Try an other dyno.</TD></TR></TABLE>
My car is JDM , and my mods are :
Engine
Mugen exhaust manifold 4-2-1 Gymkhana spec
Mugen V1 oil filler cap
Tanabe SMR cat back exhaust system
Custom made stainles steel decat pipe
Spoon Sports hi pressure radiator cap
Spoon Sports computer ECU
Ultra blue Spark plug wires
NGK platinums spark plugs
ENJO OE upgrade 3 motor mounts
OEM torque mounts with energy suspension inserts
HKS super power flow air filter
AEM cold air intake system
AEM hi volume fuel rail
AEM fuel pressure regolator
Sard fuel pressure guage
Drivetrain
ACT prolite Flywheel 8.8lbs
ACT XTSS clutch kit
JDM 4.785:1 final drive
at 7900 - 8000 rpms the Hp is 204
I will post the graph as soon as I hook up my scaner.
Old Mar 20, 2005 | 05:28 AM
an2ny888's Avatar
have you ever opened up your spoon ecu? what version is written on the spoon chip inside? mine says version 6, just want to know if there are newer and better versions of the spoon ecu
Old Mar 22, 2005 | 01:04 PM
Marlon88's Avatar
Default Re: Dyno results . (an2ny888)
an2ny888 No I did not open up my Spoon ECU so I don`t know what version is my chip . when I get the chance to open it up I will let you know .
Here is the dyno graph as I promised guys ....
Tell me what you think !?
thanks
Marlon
b20beast83
41
Mar 7, 2009 02:47 AM
IntegraTionR
Nov 20, 2007 04:07 PM
gser67
Jul 22, 2004 09:06 AM
cpforyou
Jul 13, 2003 11:21 AM
Cova85
Nov 12, 2002 01:34 PM
