gsr throttle body on a d16?
Old Mar 12, 2005 | 04:55 PM
donaldmejr's Avatar
Default gsr throttle body on a d16?
will a gsr throttle body fit on a d16 engine if so how? any help would be great or just links on how to do it would be wonderful.
Old Mar 12, 2005 | 05:05 PM
Grand's Avatar
whate type of gsr any b series throttle body bolts right to a d series manifold
Old Mar 12, 2005 | 05:11 PM
donaldmejr's Avatar
Default Re: (LG_R32)
not sure what type but i was wondering about the throttle cable arent the two different or backwards(this is what I was told) if so how would you modify it to work on my d16a6 intake manifold.
Old Mar 12, 2005 | 05:35 PM
donaldmejr's Avatar
ttt
Old Mar 12, 2005 | 05:42 PM
Fobtions's Avatar
Default Re: (donaldmejr)
if it bolts on, all u gotta do is switch the cable pulley "to your old sohc one" so it doesnt pull the other way.
easy.
Old Mar 12, 2005 | 05:45 PM
donaldmejr's Avatar
Default Re: (Fobtions)
how do you do that
thanks man
Old Mar 12, 2005 | 05:47 PM
Redline130's Avatar
Default Re: gsr throttle body on a d16? (donaldmejr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donaldmejr &raquo;</TD></TR><TR><TD CLASS="quote">will a gsr throttle body fit on a d16 engine if so how? any help would be great or just links on how to do it would be wonderful.</TD></TR></TABLE>
If you are talking about a D16A6, then no, it will not bolt on. The bolt pattern of the A6 throttle body is different from all B-series and 92-up D-series throttle bodies.
Old Mar 12, 2005 | 05:59 PM
donaldmejr's Avatar
well we also have other intake manifolds laying around from eg's and ek's but how do you switch them?
Old Mar 12, 2005 | 06:06 PM
Redline130's Avatar
Just take off the injectors and all the vaccum and coolant hoses that are attached to the existing manifold, and unbolt it. The just replace it with whatever other manifold you want to use.
1badteg
Apr 12, 2008 02:38 PM
tatted91rex
Dec 22, 2006 07:55 AM
JeffBro
Aug 16, 2006 07:34 PM
dxcivic
Feb 17, 2003 03:56 PM
