Aluminum MIG'n. What Voltage, wire speed, gas psi for best results?
Old Mar 12, 2005 | 04:48 PM
93LSivic's Avatar
Default Aluminum MIG'n. What Voltage, wire speed, gas psi for best results?
Im using a 220v Millermatic 175 with 100% argon for gas.
I cant seem to get a bead at all. Just bird droppings. Where should I have the controls set at? Im also unaware of the type of aluminum I am welding, but its the kind you can typically pick up at Home Depot.
Thanks..
Old Mar 13, 2005 | 03:32 AM
Want2race's Avatar
Default Re: Aluminum MIG'n. What Voltage, wire speed, gas psi for best results? (93LSivic)
what did you prep the surface with ?
Old Mar 13, 2005 | 07:56 AM
quickersol's Avatar
Default Re: Aluminum MIG'n. What Voltage, wire speed, gas psi for best results? (Want2race)
add more wire speed or less voltage. i welded 1/4" thick material with about 130 amps and #9 wire speed out of #10 on a hobart handler 135. you really need the wire speed fast as fuc if your doing aluminum and you need to weld really fast as well. you need straight argon (no mix) and i think i had my flow set at 30 or so (i usually run around 18-20 on steel)
Old Mar 13, 2005 | 10:27 AM
Flashmn's Avatar
Default Re: Aluminum MIG'n. What Voltage, wire speed, gas psi for best results? (quickersol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I cant seem to get a bead at all. Just bird droppings.</TD></TR></TABLE>
Very familiar..
Old Mar 13, 2005 | 07:18 PM
Want2race's Avatar
Default Re: Aluminum MIG'n. What Voltage, wire speed, gas psi for best results? (Flashmn)
and make sure you have the right lining for your gun!
Old Mar 14, 2005 | 06:23 AM
legendboy's Avatar
Its not gonna work great period for ya no matter what you do. Maybe for messy tack welds, thats about it.
that-guy
Welding / Fabrication
17
Jun 20, 2011 06:16 AM
that-guy
12
Mar 23, 2011 09:48 AM
kuja396
Mar 13, 2008 02:40 PM
LostAndFound
Oct 30, 2006 04:04 PM
Eucalyptus lude
Aug 27, 2004 12:28 AM
