dohc Zc with a bit over 80k miles on it...Rebuild???
Old Mar 12, 2005 | 03:56 PM
ivanson's Avatar
Default dohc Zc with a bit over 80k miles on it...Rebuild???
A friend of a friend is going to sell me a dohc Zc and im wondering if
i should rebuild this puppy.. If i do rebuild ,what is the procedure of this process
and the cost?..reply back thanks.
Old Mar 12, 2005 | 04:16 PM
86si's Avatar
Default Re: dohc Zc with a bit over 80k miles on it...Rebuild??? (ivanson)
80k ... leave it alone and drop it in. maybe check the t-belt and tune up before you install it
Old Mar 13, 2005 | 02:26 PM
dragaholic's Avatar
definitely change the timing belt. once yuh cross the 60,000 mark it is recommened
Old Mar 13, 2005 | 02:57 PM
FLOWZILLA's Avatar
Default Re: dohc Zc with a bit over 80k miles on it...Rebuild??? (dragaholic)
t belt is a must .. leak down test the engine . take off the valve cover and visually inspect it make sure that there are no signs of motor fatigue
Old goat
Dec 31, 2009 06:49 AM
WestSideRain
Jun 27, 2009 02:44 PM
MooreBoost
Jul 8, 2004 05:34 PM
90hatchsi
Feb 26, 2004 03:22 PM
