Serious problems with axles in ZC tranny swap
Have a 91 CRX Si with DOHC ZC motor. The stock trans took a **** so i got a ZC tranny. I have been told to get axles for a 90 integra when using the DOHC ZC tranny swap. Is this correct? My problem is when i put the axles in and go to tighten the nut on the end of the axle i can't turn the wheel. Something seem to be binding. Do i need diff brake? Different hubs, different axles? Does anyone know what the problem is with what i have and why it won't work?
this is just a suggestion, but have you tried removing the small dust rings on the inside of the hubs? i know that when using 90-93 integra axles with a b series swap, you have to remove the dust rings or the axles will bind....maybe that is the case here as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">this is just a suggestion, but have you tried removing the small dust rings on the inside of the hubs? i know that when using 90-93 integra axles with a b series swap, you have to remove the dust rings or the axles will bind....maybe that is the case here as well.</TD></TR></TABLE>
BINGO!
BINGO!
crxguy406
Jun 29, 2013 09:50 PM
onefiine69
22
Mar 29, 2005 06:34 PM
onefiine69
Mar 14, 2005 06:03 AM
onefiine69
Mar 7, 2005 06:42 PM
