best clutch from exedy for a 95 integra ls turbo?
Old Mar 12, 2005 | 01:27 PM
bukbukintegra's Avatar
Default best clutch from exedy for a 95 integra ls turbo?
hello, i was wondering what clutch built by exedy would be the best for my setup... i have a 95 acura integra ls turbo (b18b) non-vtec... the car has dynoed at 226HP @ 196lb-ft on 7psi of boost... i am deciding whether to go ACT Heavy Duty with Street Stip disc, or a clutch kit from exedy... problem is i don't know which is best... i want something not too strong like the 6 puck, but something that will last long and not slip... let me know guys! thanks!
-dj
Old Mar 12, 2005 | 02:22 PM
Targa4Life's Avatar
Default Re: best clutch from exedy for a 95 integra ls turbo? (bukbukintegra)
Ya im running a really similar setup as you with almost identical dyno numbers and im using an exedy stage 2 clutch with a 8.9 ACT lightweight flywheel and I have no problems. excelent hook up even with LSD. Im very anxiouse to see what my car will run in the quarter mile since once I finished building my car It was time to store it for winter. At least now I know what kind of numbers to expect.
Old Mar 12, 2005 | 02:27 PM
Default Re: best clutch from exedy for a 95 integra ls turbo? (Targa4Life)
stage 2, hows the pedal effort on that thing? is it like a 6 puck? yea i hope to be hitting 12's with a new clutch, the old one was slipping...
Old Mar 12, 2005 | 03:34 PM
virusiidx's Avatar
i need a similar clutch too for about the same setup as you, is it really neccessary to change to a lighter flywheel, i was hoping to keep my stock one.
Old Mar 13, 2005 | 07:24 PM
bump
DCkazi
May 8, 2006 07:36 AM
4drITR
Oct 31, 2005 11:35 AM
bukbukintegra
Mar 13, 2005 07:30 PM
bukbukintegra
Oct 22, 2004 12:39 PM
