OBD 2 ECU swap now wont start
Old Mar 12, 2005 | 10:19 AM
skimb37's Avatar
Default OBD 2 ECU swap now wont start
i have a 97 lude base 5spd and the ECU got wet, it still runs the car but misses sometimes so i bought a new ECU and i hooked it up and my car wont start. it was from a 97 base 5spd any help?
Old Mar 12, 2005 | 10:23 AM
A Blue Lude's Avatar
Default Re: OBD 2 ECU swap now wont start (skimb37)
5th gen ECUs have an immobilizer...if you're using your old key, it's not going to start the new ECU.
Old Mar 12, 2005 | 10:25 AM
skimb37's Avatar
Default Re: OBD 2 ECU swap now wont start (Featherfire)
can i bypass that or do i need the key to the other guys car with his ignition?
Old Mar 12, 2005 | 11:23 AM
bad-monkey's Avatar
1) put your old ECU back in.
2) go to the honda dealer with your master (red) key and new ecu.
3) ask them to reprogram immobilizer for new ECU. should cost 75 bucks or so.
4) suggest that you swap ECU's in their parking lot to save yourself the money because they need the new ECU connected to the car to reprogram the immob.
Old Mar 12, 2005 | 11:58 AM
skimb37's Avatar
Default Re: OBD 2 ECU swap now wont start (bad-monkey)
thanx
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
Lissav
Jan 14, 2006 08:39 AM
MaWeiTao
Apr 11, 2005 11:39 AM
