7th Gen Accord Info
Old Mar 12, 2005 | 07:53 AM
hondapwr's Avatar
Default 7th Gen Accord Info
Does anyone have info on the 7th Gen Accord yet? (2003-2005)
Specifically:
1. Which parts from other Honda's are compatible with the Accord? EP3 springs, DC5 intake, etc.
2. Break down of the K24A4 and other K engines (Gear ratios, compressions, cam profiles, etc)
3. Where to find compatible aftermarket parts? (Brakes, coilovers, rear stabilizer etc)
Thanks
Old Mar 16, 2005 | 04:50 PM
hondapwr's Avatar
Default Re: 7th Gen Accord Info (hondapwr)
Ok, no one has any info? I guess I'll just dump my notes, and hope we can build from there.
#Begin dump
2005 Accord LX Sedan (4cyl/MT)
*Coupe may have more parts available, but costs $3k more (headers, chassis brace)
Stabilizer Bar 25.4mm-front/14mm-rear
Front Disk/Rear Drum (ABS)
Double-wishbone
15in Steel Wheels
5-speed manual
K24A4 2354cc, 9.7:1, 87mmx99mm, 160hp@5500, 161lb-ft@4500, LEV-2
Curb Weight = 3115sdn, 3056cpe
CD = .30
Standard Remote Entry
AC with filtration
Driver's seat with power height adjustment??
6 Speaker CD Audio
Front and Side Airbags
Honda Supplied Swap Parts
Accord EX disc brakes may fit
Parts to apply immediately
Larger front stabilizer bar (Neuspeed 27mm)
Larger rear stabilizer bar (Neuspeed 19mm)
Poly shifter and steering rack bushings
Adjustable springs, struts, with camber adjustment (1/2in drop max)
Better front brake pads
Wheels = Kosei K1 TS 17x7 5-114 Light Grey Painted (13.7lbs) $199each
Tires = 215/45R17 Potenza G009 (1st choice), or RE950 (2nd choice)
Front Upper tiebar (Neuspeed)
Replace fluids with synthetic? (Brake, clutch, trans, engine)
Billet Shift **** (DC) 6spd?
Short shift kit (Neuspeed)
Better front seats
Improve Engine Performance (200WHP goal)
K20A or K20A2 Head, oil pan, crank pulley, windage tray, and transmission swap?
Higher Compression Pistons 87mm (Prefer Honda)
Header (DC), Exhaust, Intake Manifold (JDM?), CA-Intake (AEM)
ECU
Other Parts
Lightweight hood
#End dump
Old Mar 17, 2005 | 04:23 PM
hondapwr's Avatar
I just found a way to stuff even more rubber under the 03+ Accord.
This is sold at tirerack.com
Wheels = Kosei K1 TS 17x8 5-114 Light Grey Painted (15.4lbs) $239each
Tires = 225/45R17 Potenza G009
Old Mar 19, 2005 | 11:11 AM
hondapwr's Avatar
I found a carbon fiber hood!
http://www.customcarbons.com/p...id/34
They make on for the coupe too. =]
sky9
Feb 23, 2011 08:43 PM
bigdaddycustoms
Jul 5, 2009 12:25 PM
sEvoIXnTurboS2k
Apr 26, 2009 07:41 PM
accordselux
May 29, 2008 09:16 AM
RobertNg
Dec 12, 2005 07:12 AM
