Brothers, After basic bolt-ons...civic type R cam best mod? $400 to spend..
Old Mar 12, 2005 | 07:11 AM
Integgin's Avatar
Default Brothers, After basic bolt-ons...civic type R cam best mod? $400 to spend..
2000 gsr here guys...
I just finished basic bolt-ons on my car..i/h/e....i got about $400 dollars to spend give or take a little....i seen ctr cams for sale for about $240....prior to getting ctr cams..what else do i need for the cams to get the best out of them...v-tech controller? different ecu? cam gears? springs? retainers? im limited to about gettin one more thing..but if its a necessity i can defintely get 2....please respond back with any advice or opinions you guys can give me..Thanks!
Old Mar 12, 2005 | 08:04 AM
xx dc2teg xx's Avatar
Default Re: Brothers, After basic bolt-ons...civic type R cam best mod? $400 to spend.. (Integgin)
if your gonna go with cams I would save a little more so you can everything at once. Springs and retainers are up to you, ctr cams don't really make power above ur rev limiter.
Cam gears and some kind of piggyback tuning device is recommneded. I would also look into A/f guage and fpr.
Old Mar 12, 2005 | 08:10 AM
shermanyang's Avatar
Default Re: Brothers, After basic bolt-ons...civic type R cam best mod? $400 to spend.. (xx dc2teg xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx dc2teg xx &raquo;</TD></TR><TR><TD CLASS="quote">if your gonna go with cams I would save a little more so you can everything at once. Springs and retainers are up to you, ctr cams don't really make power above ur rev limiter.
an a/f guage is definately not needed. it's more of a light show than anything else.
Old Mar 12, 2005 | 08:19 AM
lanojp1's Avatar
i have the CTR cams in my GSR, i like them alot but I would recommend installing alot more to ur head at one time while you have it ripped open...it will save you time and money...with that 400 i would buy a nice FPR...
Old Mar 12, 2005 | 08:56 AM
Integgin's Avatar
Default Re: (lanojp1)
So basically a FPR is needed to tune correct? Can i run on my stock gsr ecu? Thanks..you guys have been great...and one more question...one of you said that i won't make that much power with ctr cams...is this true?
Old Mar 12, 2005 | 09:20 AM
iH8RICERZ's Avatar
Default Re: (Integgin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integgin &raquo;</TD></TR><TR><TD CLASS="quote">So basically a FPR is needed to tune correct? Can i run on my stock gsr ecu? Thanks..you guys have been great...and one more question...one of you said that i won't make that much power with ctr cams...is this true?</TD></TR></TABLE>
I wouldnt waste money on the fpr until you have more mods done....also, your stock gsr ecu will be fine if your still using the stock gsr intake manifold. I'm running CTR intake cam on my GSR....you feel only slight gains in the high end. IF I were to do it all over again, I'd save up a little more and buy the Rocket Motorsports head package. (ie. cams/valve springs/retainers) I'm definately sure you'll feel and see some nice performance then
Old Mar 12, 2005 | 10:09 AM
Integgin's Avatar
Default Re: (iH8RICERZ)
Does Rocket Motorsports have a website?
Old Mar 12, 2005 | 10:28 AM
iH8RICERZ's Avatar
i just bought some rocket valve springs from rtzcom . His original post:
https://honda-tech.com/zerothread?id=1136006
you can also check out kteller.com or PM Rocket himself here on h-t.
92integraVTECgsr
15
Oct 9, 2007 06:34 PM
t-powersi
Sep 13, 2007 09:06 PM
Kr4nG
Jul 13, 2007 02:02 PM
crazyimport
Apr 20, 2004 07:56 AM
VTECAcuraGSR
Jun 17, 2001 06:18 PM
