Suspension & Brakes Theory, alignment, spring rates....
Ground Control Coilovers with.......
Old Mar 12, 2005 | 04:52 AM
jakeiscool's Avatar
Banned
Default Ground Control Coilovers with.......
Should I go with KYB AGXs or Koni Yellows? Its a price difference of 200 bucks. Both shocks are adjustable, both have been used by accord people for a while. I am leaning toward the KYBs. What do you fellas think.
Old Mar 12, 2005 | 05:35 AM
jakeiscool's Avatar
Banned
Default Re: Ground Control Coilovers with....... (JakeIsCool)
bump
Old Mar 12, 2005 | 10:34 AM
bad-monkey's Avatar
depends on the spring rates and what you will be doing with the car.
the koni's will perform better in more situations and for higher spring rates, but if you're going to order the GC's with softer springs (or the typical GC spec 380F/250R springs) you can use the AGX's. and if you're not tracking the car or otherwise driving it competitively, the AGX's should be fine for street use.
however, if you want more, the konis are well worth the money.
Old Mar 12, 2005 | 12:31 PM
The Internet Tough Guy's Avatar
Default Re: (bad-monkey)
koni yellows are great shocks, i highly recommend you save up and go with them.
Old Mar 13, 2005 | 01:06 PM
eMpAtHy's Avatar
Default Re: (jwn7)
you can get used ones and send them to crxlee or something like that and he can revalve them and make them stiffer and better than original koni yellows.
Old Mar 13, 2005 | 03:51 PM
00R101's Avatar
Koni Yellows - this is a no-brainer. The Konis are much, much better. They are rebuildable. They carry a lifetime guarantee. You can have custom work done on them if you decide to support heavy spring rates (over about 550 lbs)
Old Mar 22, 2005 | 05:01 PM
eMpAtHy's Avatar
i think kyb agx's carry a lifetime warranty too. they have a 1.5 inch drop rule, but since you are going to have coilovers..
if you ever blow your shocks, just raise your car and go get urself a new set.
Old Mar 22, 2005 | 05:52 PM
.water's Avatar
Default Re: Ground Control Coilovers with....... (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">i think kyb agx's carry a lifetime warranty too. they have a 1.5 inch drop rule, but since you are going to have coilovers..
if you ever blow your shocks, just raise your car and go get urself a new set.</TD></TR></TABLE>
hahahaha..tricky tricky
Old Mar 22, 2005 | 09:28 PM
SkankyEJ7's Avatar
http://www.kyb.com/service/warranty.php
i have kyb agx's, but i wish i had koni yellows
so the max i could use on my agx's would be around 380 or 400? but could i still do an occasional auto X?
Old Mar 23, 2005 | 08:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Ground Control Coilovers with....... (hondakid1)
They will be able to tell how low your car was once the blown shocks are disassembled. It has been discussed in many other threads. The question is weather or not you will be dealing with the shop you purchased them from, or KYB directly...
I would get the Koni Sports. Oh wait, I already did... If you like your car low, you don't have to worry about your warranty, you can set them nice & stiff for fun driving, and there is a brake line bracket trick that can help add shock travel to the front end (if Accords front Konis are like Civics)...
Old Mar 23, 2005 | 08:55 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Ground Control Coilovers with....... (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KYB warranty &raquo;</TD></TR><TR><TD CLASS="quote">The warranty is void if the product is used on excessively lowered (over 1.5") vehicles or in an aftermarket coilover suspension system</TD></TR></TABLE>
I esspecially like the second part where it tells the retailers what to look for, to void the warranty.
Old Mar 23, 2005 | 01:39 PM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I esspecially like the second part where it tells the retailers what to look for, to void the warranty. </TD></TR></TABLE>
crap! i didnt know that they did not work with coilovers
go with the damn koni's.
well, ill figure out a way to get them back..like putting my springs back on. my car isnt very low..so i dont think i will have a problem with it being lower then 1.5 inches.
Old Mar 23, 2005 | 02:16 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Koni fer shizzle
datssoled
Suspension & Brakes
Aug 17, 2009 01:25 PM
2DoorBandit
Suspension & Brakes
Nov 7, 2005 10:53 PM
Goodbye My Love
Suspension & Brakes
Jul 12, 2005 08:32 PM
Memo6453
Aug 26, 2004 01:06 PM
cichlid
Mar 23, 2003 09:19 AM
