jdm console into usdm teggie... can it work ???
aight well my g/f got bit by the jdm bug and she went and splurged she bought a jdm itr console but i cant figure out how to get it to fit the slant of the console is exactly opposite ... does anyone know a way to make it fit if not ne know where i can get a usmd itr console ??? please let me know SHE DRIVING ME NUTS!!!!!!!!!!
i dont remeber the link but i think i read that u can change the inside to the usdm one and than get the light bulbs. i dont really know. someone help em out
I'll drop my input....
Climate control: Should snap right in. just flip the cable that opens the heater door towards the pass. side instead of the drivers side.
Cig Lighter/Ash Tray: I think this is where you're stuck. I've fiddled with this part and started shaving the console itself to make room for the ash tray. Fact of the matter is, you'll have to shave the ash tray on the right side to follow the shifter consoles contour. Trace the edge of your USDM cig lighter on a piece of paper. use that as a template to follow while you shave the ash tray panel. Then, to mount it down, make a brace using a piece of flat stock and screw it into one of the exsisting holes. Then drill a new hole for a screw to lock into that matches the JDM mounting holes. FInally, cut the 2 tabs that are supposed to clip into the center part of the dash. TOTAL mutilation, its almost not worth the trouble. I can snap pictures if you're seriously going to do this.
Shifter plate: If you must use this as well, be sure you're willing to live with slight gaps and/or irregular fitment. I just seated the shifter plate into the console and shaved areas with a dremel until it fit. Was not perfect, but it sat in there.
For USDM parts: Check the classifieds. Be patient and make sure you're not buying JDM type r pieces....or you'll run into the same dilemna.
Hit me up at one of my contacts if you need further assistance. Goood Luck!
92BlackSi
Oct 13, 2003 01:31 AM
bartek_b
Aug 3, 2003 10:03 AM
