89 CRX HF Headlight?
Old Mar 11, 2005 | 09:42 PM
bumluck's Avatar
Default 89 CRX HF Headlight?
I just bought a crx hf and it runs great...but there is a minor problem with headlights. When i turn the switch to on position, they usualy come on...but not always, and as i drive they sometimes turn off then come back on. I found that for a while tapping the switch would get them to come back on, but now they wont come on at all. The part that really bugs me is that the brights work fine...and yes i changed the bulbs, and checked the connections on the lights them selves...any help would be great.
Old Mar 11, 2005 | 10:32 PM
Magick211's Avatar
Default Re: 89 CRX HF Headlight? (bumluck)
If all the connections are fine and there is no shorts in the wiring. It may be a bad switch. You have any friends with ef's? if so try to use one of there switches and see if it fixes the problem
Old Mar 11, 2005 | 10:35 PM
CRseXy's Avatar
Default Re: 89 CRX HF Headlight? (Magick211)
Ide replace the switch, there like what 5 bucks are the pick and pull?
hcjason
Aug 28, 2009 06:45 AM
Canadian_EF
Jun 23, 2009 07:18 PM
MDAnhorn
Oct 18, 2005 01:27 PM
MugenHonda
May 30, 2005 08:29 AM
