swap help
Old Mar 11, 2005 | 09:26 PM
1gEF-8's Avatar
Default swap help
i just installed my d16z6. the engine fires up but has no throttle response. if you hold down the throttle (wot)it will take bout 5-10 sec before the rpm starts to rise. during initial fire up the rpm shot up to 4500 rpm. im still running od0. no codes what so ever. im stumped. there is also alot of backfire when the engine warms up. goin to check timing tomorrow. any help will be greatly appreciated.
Old Mar 11, 2005 | 09:48 PM
Magick211's Avatar
Default Re: swap help (1gEF-8)
Sounds like timing is off. Did you put a new timing belt on it? might of be a few teeth of on the cam
Old Mar 11, 2005 | 11:46 PM
1gEF-8's Avatar
Default Re: swap help (Magick211)
nope
Old Mar 12, 2005 | 03:17 PM
1gEF-8's Avatar
timing is way off. when i line up the timing marks on the crank pully it revs to 4000 rpm.
Old Mar 12, 2005 | 05:50 PM
Redline130's Avatar
What distributor are you using?
Old Mar 12, 2005 | 07:02 PM
1gEF-8's Avatar
Default Re: swap help (Redline130)
the one from my a6
jdmkid_82
Oct 25, 2008 04:06 PM
1990si
21
Feb 1, 2007 02:54 PM
integra3586
Oct 15, 2005 01:56 AM
jas_honda_uk
May 6, 2002 07:29 PM
