DA: Minimum Flywheel Thickness/Weight
Anyone know what the Factory service manual says? I don't need anyone replying with things like 'u c4n g0 like 7lbz y0.'
I'm just looking to stay as OEM as possible with the least amount of weight possible. TIA
OEM as in OEM DA flywheel. I'd like to machine it down to the minimum thickness allowed in the Factory service manual.
SCCA's STS class won't allow anything other than an OEM flywheel.
Modified by DA9 Integra at 5:19 PM 3/22/2005
The factory manual won't actually give you the lowest allowable weight - it'll give you a service limit that the stock one can be machined down to. My repair manual's back home so I can't read you those specs off hand, but someone probably can.
The lowest I've heard of is 7.** pounds aftermarket. Fidanza..maybe? I think my Fidanza is 8 lbs, or something around there. Perfect weight for me, IMO.
If you want OEM, you can buy a used Type-R flywheel for around $100 depending where you look. Those are 14 lbs compared to our 18 lb factory flywheels (correct those numbers if I'm wrong). You won't notice a large difference, but I'm sure it's enough to notice. My 7 lb flywheel didn't make *that* much of a difference, so go figure
I'm sorry, OEM as in OEM DA flywheel. I'd like to machine it down to the minimum thickness allowed in the Factory service manual.
psychotic_z - If you could check that'd be great.
To everyone else: I'm not looking for an aftermarket, OEM ITR or any other OEM clutch. Just the minimum allowed for the DA chassis.
Heh sorry, misunderstanding - My manual's at home home and I'm in school 200 miles away
I'll be heading back for Spring Break on Monday or Tuesday, and if no one's answered this for you yet, I'll look it up and check it for you
But seriously, some of you guys looking at this post have to have their Haynes or Helms manual sitting around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z »</TD></TR><TR><TD CLASS="quote">I'll be heading back for Spring Break on Monday or Tuesday, and if no one's answered this for you yet, I'll look it up and check it for you
wewt
</TD></TR></TABLE>wewt
Hey sorry bro, I completely forget about this thread this week. I just looked up my Helms for a flywheel spec. and surprisingly - there's nothing about minimum thickness. The only flywheel specification listed is clutch surface runout. A minimum thickness isn't even suggested.
This is the Helms as well - if it's not in here, the Haynes or lesser manuals won't either. You'd figure they'd list something like that but... I think your best bet is doing some research into how low other people shave theirs and doing some experimenting of your own.
to SCCA racing - Good luck bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard »</TD></TR><TR><TD CLASS="quote">good job,now your thinking . . you think maybve when you made this thread you should i have said that ??
and wait a second they let dumb people who dont know anything on the track ??
are you sure you dont just bench race at nascar events ??
Not to interupt you bro... but, he did mention that. Just let it go...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Integra »</TD></TR><TR><TD CLASS="quote">I'm sorry, OEM as in OEM DA flywheel. I'd like to machine it down to the minimum thickness allowed in the Factory service manual.
To everyone else: I'm not looking for an aftermarket, OEM ITR or any other OEM clutch. Just the minimum allowed for the DA chassis.</TD></TR></TABLE>
ok, i'll edit all my posts, but apologize for insulting me both times, and put at the begining of your thread that you need to stick with a da flywheel for STS class (scca)
ty
the only reason i got mad is because of the insults btw
Modified by jason bouchard at 7:29 AM 3/22/2005
ty
Lou_EM1
May 8, 2017 09:40 PM
yellowturbo
Nov 21, 2005 09:38 AM
