MY INTAKE CAM HAS DEEP SCRATCHES IN IT
So what's your question? Is it "why does your intake cam have deep scratches in it?" This is the result of over-revving the motor
they are deep grooves, i can feel them with my nail. my rockers have small scratches on them also. i am running rs machine stage 3 cams and have rs valve springs and retainers. i got a couple of opinions, one said my head is warped and that is why my cam is scarred.
The scratches are probably caused by an improperly heat treated camshafts matched with too strong valve spring pressures. Tme to change the cams before you hurt more parts.
i am running 11.8:1 compression pistons w/ an 84.5 mm bore in a crv block, i am planning on getting a ctr int cam and a itr exh cam, does anyone recommend different cams with my setup?
crower_h22a
Jul 29, 2004 02:50 PM
Death_to_Thieves
Dec 5, 2002 11:00 AM
