can you please help me? problems on a eg hatch
Old Mar 11, 2005 | 06:30 PM
JCR13's Avatar
Default PLEASE HELP ME? problems on a eg hatch swap
i'm having some problems with my hatch, i recently did a swap, my car moves but theres one problem it chokes sometime when i press the gas can it be the fuel pump or another problem. can someone help me please? i did a gsr swap..
Modified by sharday at 8:20 PM 3/11/2005
Modified by sharday at 8:21 PM 3/11/2005
Old Mar 11, 2005 | 07:43 PM
Aespooncivic's Avatar
Default Re: PLEASE HELP ME? problems on a eg hatch swap (sharday)
Why the **** did u post twice? https://honda-tech.com/zerothread?id=1176587
Old Mar 11, 2005 | 07:52 PM
eg4usdm's Avatar
umm your fuel pump could be bad, you could always get new injectors. it def sounds like a fuel problem though. i would just go through and check my fuel filter, injectors, pump, rail. i dunno just go down the check list or something
Old Mar 11, 2005 | 08:51 PM
DCStreetHtch's Avatar
Default Re: PLEASE HELP ME? problems on a eg hatch swap (eg4usdm)
you need to narrow things down more.
this could be anything haha
Old Mar 12, 2005 | 06:26 AM
JCR13's Avatar
Default Re: PLEASE HELP ME? problems on a eg hatch swap (EGStreetHtch)
okay atleast 15 to 20 minutes after starting my car, it starts to act up, it chokes while i'm driving, it will do it for atleast 5 minutes and then stop but i hate that **** it aggrevates me, so would it be the fuel pump...
Old Mar 12, 2005 | 07:04 AM
EG6[B16A1]'s Avatar
maybe bad coils? does your check engine light come on? check the codes first.
Old Mar 12, 2005 | 08:35 AM
Evil-EK's Avatar
Default Re: PLEASE HELP ME? problems on a eg hatch swap (EG6[B16A1])
did you replace the fuel filter when you did the swap?
Old Mar 12, 2005 | 10:32 AM
JCR13's Avatar
yes my check engine light is on, and i did change the fuel filter, i really appreciate you guess help me thanks
Old Mar 12, 2005 | 11:13 AM
DelSolDon's Avatar
retrieve the CEL, then post back. if you're getting a cel its probably not your fuel pump. i'm putting my $$$ on timing or a sensor.
aric_hatch
May 22, 2014 05:22 AM
94cxhatch
13
Jun 6, 2010 01:24 PM
GSRinGER
Sep 17, 2008 06:29 AM
datnigabluberry
Mar 29, 2007 05:53 AM
n2ob16hatch
Sep 20, 2006 07:37 PM
