welding piping with a t3 flange???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">heat it up and smack it with a hammer like jesse james does!
im Just kidding</TD></TR></TABLE>YEAAAAAAAA!!!!!!!!!!!!! lol
Oh dang that's not the proper method?
ive never done it before but was also wondering the same thing
after staring at if you a while my guess would be cutting it a bit lower and ti looks like it will get a bit more square
hows that funny .. i did that for my t25 flange collector .. and dam did it come out nice .. i fully welded the collector first .. but the opaning was a circle and didnt transistion smooth into the flange so i hit it on two sides only .. to squash it down .. then angle grind it and wala .. soo dam smooth ... nice transition with out any blockage from the flange or collector
like i said, i may not do it to a burns stainless collector, but i would do it to something i made.
seriously, heat will let you shape that into almost anything. i would put it in a vice and heat is up, and slowly tighten up the vice, equal pressure on both sides, and a vice is iron so it should take the heat nicely
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">like i said, i may not do it to a burns stainless collector, but i would do it to something i made.
seriously, heat will let you shape that into almost anything. i would put it in a vice and heat is up, and slowly tighten up the vice, equal pressure on both sides, and a vice is iron so it should take the heat nicely</TD></TR></TABLE>
thanks, good idea. I'm not trying to do it to a collector but rather just one stainless steel tube.
*Boostwerks*
Welding / Fabrication
15
Aug 24, 2006 02:40 PM
