HELP INSTALLING MASTER GAUGE 4" RPM TACHOMETER!
Old Mar 11, 2005 | 04:12 PM
cased nicotine's Avatar
Default HELP INSTALLING MASTER GAUGE 4" RPM TACHOMETER!
I have a *MASTER GAUGE 4" TACHOMETER WITH SHIFT LAMP* I need help installing it in my 1995 Honda Civic DX Hatchback.
From the tachometer there is a gray cable and a thick black one that splits into 4 cables, red, white, black, and green. HELP plz.
Old Mar 11, 2005 | 06:48 PM
93civicEX's Avatar
Default Re: HELP INSTALLING MASTER GAUGE 4" RPM TACHOMETER! (cased nicotine)
green-tach
white- light?
red- 12volt power
black- ground
Old Mar 12, 2005 | 08:28 AM
PrettyLude's Avatar
green-tach signal ------------>goes into the engine bay bay ur driver strut tower
white-illumination or lighting------>goes into ur dimmer switch, one wire will put power out when lights are turned on
red-power
black-ground
Old Mar 19, 2005 | 11:47 AM
vi3t_dude's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">green-tach signal ------------&gt;goes into the engine bay bay ur driver strut tower
white-illumination or lighting------&gt;goes into ur dimmer switch, one wire will put power out when lights are turned on
red-power
black-ground</TD></TR></TABLE>
what is the driver strut towerr?
Old Mar 19, 2005 | 12:08 PM
vi3t_dude's Avatar
Default Re: (vi3t_dude)
bump need information soon please to install my tach
Old Mar 20, 2005 | 01:01 AM
PrettyLude's Avatar
look where your grommet is by the master cylinder, there should be a connector with a cap right there, the blue wire is the tach signal
c_buz
Audio / Security / Video
Jul 25, 2006 07:19 PM
jdl3000
Jul 15, 2004 05:35 PM
tyflip2
May 26, 2004 07:13 AM
JDMRob
Jan 23, 2004 03:52 PM
b20b
Jan 24, 2002 06:59 PM
