Those with Amps
Old Mar 11, 2005 | 03:49 PM
94civicEX's Avatar
Default Those with Amps
Where exactly did you install them? Pictures?
TIA
Old Mar 11, 2005 | 03:54 PM
Haleiwa-Brando's Avatar
Default Re: Those with Amps (94civicEX)
Here:
https://honda-tech.com/zeroforum?id=27
94civicEX's Avatar
Default Re: Those with Amps (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Here:
https://honda-tech.com/zeroforum?id=27</TD></TR></TABLE>
I know, but I'm interested in Integra's specifically.
Old Mar 11, 2005 | 05:14 PM
redGSRguy's Avatar
Mine is under my passenger seat, You can put it behind the rear seats too. There is a thread with installs in the a/v forum if I remember correctly.
Old Mar 11, 2005 | 05:19 PM
migs's Avatar
Default Re: Those with Amps (redGSRguy)
When I owned an amp, which was years ago. It was installed directly behind and on the back seat.
Old Mar 11, 2005 | 05:23 PM
TunerN00b's Avatar
Under the passenger seat. Though, the drivers seat might have been better, since it doesn't slide forward when you let passengers in the back.
Old Mar 11, 2005 | 05:59 PM
SYTFU Tommy.'s Avatar
Default Re: Those with Amps (TunerN00b)
get some self tapping screws and a power drill. screw it into the metal part of the rear seats.
Old Mar 11, 2005 | 07:00 PM
PLAGUED_DB7's Avatar
Default Re: Those with Amps (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">get some self tapping screws and a power drill. screw it into the metal part of the rear seats.</TD></TR></TABLE>
Yup..the gods have spoken
Old Mar 11, 2005 | 07:28 PM
DarkDragon's Avatar
Default Re: Those with Amps (PLAGUEDNEEDSBOOST)
installing a amp in this position tends to make them over heat, with the amp when u bought it it should have a book that tells u the dos and dont of installing the amp
Old Mar 11, 2005 | 07:39 PM
XplodeTeg's Avatar
my amp is screwed onto rear seats. sometimes the amp goes into protection mode and i dont know why. if i listen to music for a long time then it goes to protection also.
Old Mar 11, 2005 | 07:41 PM
Default Re: (XplodeTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XplodeTeg &raquo;</TD></TR><TR><TD CLASS="quote">my amp is screwed onto rear seats. sometimes the amp goes into protection mode and i dont know why. if i listen to music for a long time then it goes to protection also.</TD></TR></TABLE>
simple, the amp isnt poerful enough to support ur subs. thus listening for too long, it over heats so it goes protective so nothing will be damage. once it have enough time for it to cool down, it will be normal again.
Old Mar 11, 2005 | 08:13 PM
calxtreme's Avatar
I did some installs where I would put the amp on top of the spare or next to the spare. So the amp would be out of the way.
Old Mar 11, 2005 | 08:54 PM
DarkDragon's Avatar
like i said in that position the amp doesnt have suffiecent cooling and over heats which is y it goes into protecton mode
Old Mar 12, 2005 | 02:21 AM
Xsi's Avatar
Xsi
Under the seats all the way, much harder to steal
It does depend on the amps though, I have two alpine amps which get hot enough to melt things but they have never once gone into protection in 4 years.
Old Mar 12, 2005 | 06:51 AM
GWInquisitor14's Avatar
Default Re: (Xsi)
mine is on my rear seats also, its an audiobahn so its got a fan to cool it off
Old Mar 12, 2005 | 07:16 AM
Honda97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicEX &raquo;</TD></TR><TR><TD CLASS="quote">Where exactly did you install them? Pictures?
TIA</TD></TR></TABLE>
im comming up with a sick setup soon, when i get it installed i will post it up, u will love it!
Honda97's Avatar
Default Re: Those with Amps (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">installing a amp in this position tends to make them over heat, with the amp when u bought it it should have a book that tells u the dos and dont of installing the amp</TD></TR></TABLE>
u sound so dumb for saying that, just stop. "The Book" says keep it in a well venilated area. nothing more
Old Mar 12, 2005 | 07:48 AM
DarkDragon's Avatar
Default Re: Those with Amps (Honda97)
sure i "sound" dumb but in that position it doesnt get suffiecent cooling, with both amps i bought they came with a slip that showed positions not and to install the amps in such as not on the back of seats. Im not trying to flame people but give them the heads up. If u notice people that have instlled them in this position have had them over heat, i have mine next to my box in the hatch and they have never overheated
Old Mar 12, 2005 | 07:59 AM
jasonw's Avatar
It sounds like you have bridged your subs and are trying to run a 2-ohm stable amp at 1-ohm or maybe you have a 4-ohm stable amp and are running a 2-ohm load. That causes the amp to overheat and go into protection mode. You can try taking it out of bridged mode and just run in stereo.
When you don't have enough power, that usually causes distortion and blowing speakers, not overheating.
Two 4-ohm subs in parallel = 2-ohm load. Calculator http://hyperphysics.phy-astr.g...ml#c1
Old Mar 12, 2005 | 08:40 AM
Irish Integra's Avatar
Default Re: (jasonw)
Here's what I did with mine...nothing fancy, doesn't look all that cool, but only I have to look at it, it's not for show, works excellently and never overheats.
Old Mar 12, 2005 | 08:45 AM
eluam's Avatar
I have mine mounted to the rear seat and it has never overheated. I don't see how inside a hatch gets you better venilation than on the rear seats. Neither one I would imagine gets good venilation. In fact, I have my sub box sitting right in front of the amp, blocking it from view, so I doubt mine gets any venilation, but still doesn't overheat.
Old Mar 12, 2005 | 08:51 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: Those with Amps (geeZus)
I had an amp which was mounted to the back back seat, never had any problems. Once I upgraded, It's now on the floor of the trunk (screwed down, of course) just behind the seats, under where the rear strut tower bar would go, if i had one.
Old Mar 12, 2005 | 09:48 AM
XplodeTeg's Avatar
i have a sony xplode 480watt amp i think with sony xplode 1200watt. i dont know how my wires are connected. im wondering what u meant by "You can try taking it out of bridged mode and just run in stereo."
Old Mar 12, 2005 | 09:53 AM
wreckedmyteg's Avatar
Never had any over heating problems with my setup...we'll see what happens when I flush mount the amps in the back seats.
Old Mar 12, 2005 | 01:18 PM
Xsi's Avatar
Xsi
Theres even room for a cap under there
