Loss of power with v-tec
Old Mar 11, 2005 | 01:43 PM
Outsane's Avatar
Default Loss of power with v-tec
Set up
88 CRX si
b16a PR3 ECU
Fields sfc controller
I have on code 17 for vss no other codes, and the Fields kicks in the v-tec
when it does there is a loss of power
the A/F gauge says the fuel is rich when the v-tec crosses over..
any ideas on why?
thanks
Old Mar 11, 2005 | 03:50 PM
Combustion Contraption's Avatar
Maybe because you keep putting a dash in VTEC.
Seriously, its probably because the feilds forces the car into VTEC, but the ecu is still running on the low cam ignition map. I have no idea why youre running rich though.
Old Mar 11, 2005 | 04:55 PM
Outsane's Avatar
Default Re: (LsVtec92Hatch)
I did not know that the ignition map changes...
sounds like I should tackle this vtec issue after the vss issue is fixed then..
thanks.. for the info
Old Mar 11, 2005 | 07:52 PM
beaterdriver's Avatar
i think a vss cel would cause vtec no to engage
Old Mar 11, 2005 | 11:22 PM
Outsane's Avatar
Default Re: (beaterdriver)
the cel does stop it from engaging with out the field SFC... The Field SFC engages the vtec
nkcalvert09
Jun 11, 2011 10:43 PM
ken2830
Dec 25, 2006 11:08 AM
msbhvn_DC2
Feb 9, 2006 07:39 AM
-iLLuZioN-B18C1
Jun 14, 2003 01:48 PM
digitalhav0c
Apr 9, 2002 11:05 AM
