where is my IACV
Old Mar 11, 2005 | 01:42 PM
mintegra97's Avatar
Default where is my IACV
I have a 96 civic dx, where is this IACV located?
Old Mar 11, 2005 | 01:54 PM
bbarbulo's Avatar
I wanna say throttle body! cuz I know for sure it's not on the intake mani.
Old Mar 11, 2005 | 04:49 PM
mintegra97's Avatar
Default Re: (bbarbulo)
Old Mar 11, 2005 | 05:08 PM
KillBot's Avatar
werd. It's got a three wire plug...if that helps.
Old Mar 11, 2005 | 05:16 PM
HPCO$T's Avatar
right in front i see it 2 coolent lines going to it
Old Mar 11, 2005 | 05:21 PM
SOHCD16y8's Avatar
No, thats the FITV, The IACV is different, you can see it if you look to the back left of the throttle body, the end of it is sticking out a bit
Old Mar 11, 2005 | 07:27 PM
HPCO$T's Avatar
humm my bad mine looks just like the FITV then
Old Mar 11, 2005 | 07:55 PM
SAVIOVEGA's Avatar
Default Re: (CO$T)
Back side of Intake Manifold next to the TB
Old Mar 11, 2005 | 08:04 PM
pro547's Avatar
Default Re: where is my IACV (mintegra97)
Old Mar 11, 2005 | 08:09 PM
EK k kay's Avatar
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">No, thats the FITV, The IACV is different, you can see it if you look to the back left of the throttle body, the end of it is sticking out a bit</TD></TR></TABLE>
No that is the IACV in front on the throttle body with the green plug coming out of it.
Old Mar 12, 2005 | 05:50 AM
mintegra97's Avatar
Default Re: (chowmien)
Thanks for the help guys, never had a d series before. Not for long though k series here i come. What would you guys use to clean this out? Thanks again
Old Mar 12, 2005 | 09:01 AM
TurboEM1's Avatar
carb cleaner works great
Old Mar 12, 2005 | 11:31 AM
mintegra97's Avatar
Default Re: (TurboEM1)
just used the carb cleaner, now the car when i start it revs to like 4 and then goes between 1 and 3. did the iacv go bad. i heard carb cleaner can do that. ? ?
Old Mar 12, 2005 | 11:34 AM
DelSolDon's Avatar
Default Re: (mintegra97)
try adjusting your idle speed.
Old Mar 12, 2005 | 12:39 PM
mintegra97's Avatar
Default Re: (DelSolDon)
searched on how to do that and didn't really get an answer can someone help. just said to pull the sensor on the bottom of the iacv while car is running. is this correct?
Old Mar 12, 2005 | 01:13 PM
mintegra97's Avatar
the intake sounds extremely loud...
Old Mar 12, 2005 | 01:28 PM
mintegra97's Avatar
where is the idle speed adjustment screw on this motor also? Thanks for everyones help.
Old Mar 12, 2005 | 02:19 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">
No that is the IACV in front on the throttle body with the green plug coming out of it.</TD></TR></TABLE>
Not in the first picute which was the only one I had at the time
Old Mar 12, 2005 | 02:54 PM
honda9369's Avatar
u should also give bitchin camaro his money back
Old Mar 12, 2005 | 04:04 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Not in the first picute which was the only one I had at the time</TD></TR></TABLE>
First picture, this picture, that picture - doesn't matter. Y7's never came with FITV's to begin with.
Old Mar 12, 2005 | 04:52 PM
ej0513's Avatar
Default Re: (honda9369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 &raquo;</TD></TR><TR><TD CLASS="quote">u should also give bitchin camaro his money back</TD></TR></TABLE>
i second ^^^.. the $1100 that he paid you for that "CTR" tranny.. this guy is a scammer!
Old Mar 12, 2005 | 04:59 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> hahahhahaah looks like a vagina
Old Mar 12, 2005 | 05:02 PM
Fuster_Cluck's Avatar
Default Re: (TodaFiend)
What does IACV stand for? ...while we're on the subject
Old Mar 12, 2005 | 05:16 PM
eg6T's Avatar
Default Re: (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">What does IACV stand for? ...while we're on the subject </TD></TR></TABLE>
idle air control valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaFiend &raquo;</TD></TR><TR><TD CLASS="quote"> hahahhahaah looks like a vagina </TD></TR></TABLE>
i dont see it,or u look at some beat up pussies
Old Mar 12, 2005 | 07:20 PM
90civichb's Avatar
Default Re: (eg6T)
Good guy, i retract me previous post!
Modified by 90civichb at 9:26 PM 3/15/2005
