OBD0 to OBD1 conversion, where to get conectors?
Old Mar 11, 2005 | 11:12 AM
mrx's Avatar
mrx
Default OBD0 to OBD1 conversion, where to get conectors?
Hallo,
i plan a OBD0 to OBD1 conversion on my B16A1 CRX.
that i need the o2 sensor, a obd1 distributor and the adapter harness and a obd1 ecu is clear...
but when i install a obd1 distri and o2 sensor to my obd0 harness then the conectors won't fit.
whats better?
- replace the harness conectors to obd1's
- replace the sensor conector to obd0's
and where do i get the conectors from? is there a online shop where i can order them?
Thanks
Malte.
Old Mar 11, 2005 | 12:28 PM
Outsane's Avatar
Default Re: OBD0 to OBD1 conversion, where to get conectors? (mrx)
I got ECU plugs from the junk yard..
Old Mar 11, 2005 | 01:34 PM
xracer1966's Avatar
Most of my friends have used Hasport for their swap harnesses, and have been very happy. Good luck
http://www.hasport.com/Products/Wiring.htm
Old Mar 11, 2005 | 11:42 PM
mrx's Avatar
mrx
Default Re: OBD0 to OBD1 conversion, where to get conectors? (xracer1966)
No No, i will buy a complete ecu harness, my problem are the conectors at the distributor and the o2 sensor, NOT the ecu.
Old Mar 12, 2005 | 01:06 PM
turbox's Avatar
you have to repin the one on the dizzy or make a conversion
cut the plugs off junkyard wire harness
i bought a boomslang obdo to obd1 jumper it has wire for the o2 sensor i had to repin the dizzy no problems
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
dem0nk1d
Aug 8, 2007 02:17 PM
SI_Ro
Dec 13, 2003 01:49 PM
wickedEFguy
Feb 11, 2003 03:01 PM
h46it
Jun 18, 2002 05:23 PM
