Throwing a code 22??
Old Mar 11, 2005 | 10:39 AM
Shift_Fast's Avatar
Default Throwing a code 22??
Just got a chipped P28 ECU and right away its throwing a code 22 which is the VTEC pressure valve?? I know that I need the VTEC oil pressure sensor wire disabled in my ECU, which I don't know if it was done or not now that it is throwing this code. I have a 97 TypeR motor in a 99 Si with the OBDII to OBDI jumper harness and a chipped P28 ECU. Any help to fix this problem would be much appreciated.
Old Mar 11, 2005 | 04:26 PM
moto1320's Avatar
you can jumper proper voltage to the loose plug, tap out the housing and put in the correct switch, or go to a scrap yard or Acura to get the correct plate and sensor. They go on in about a minute.
Old Mar 11, 2005 | 06:35 PM
boosted k20's Avatar
Default Re: (moto1320)
Run uberdata to get rid of that code and have the added bonus of a standalone EMS
SiR Inspired ED7
Nov 2, 2008 05:49 PM
civic j
Jul 25, 2007 10:15 AM
ki3t
Mar 29, 2004 07:41 AM
Forrest Gump 9
Aug 3, 2003 05:44 PM
Speedz
Jun 1, 2003 07:26 AM
