Blinker Stoped Working HELP Plz
Old Mar 11, 2005 | 10:11 AM
exit3k's Avatar
Default Blinker Stoped Working HELP Plz
All my blinkers stoped working oneday so I went and checked all the fuses and found a blown fuse under the dash. I replaced it, the blinkers magicaly starting working again. I drove my car around the block and it started smelling like burnt eletrical wire then the blinkers stoped working. I went to find the fuse I replace blown. SO I replaced it the 2nd time and it doesnt even work any more. I checked the the fuses under the hood and inside the car. Includeing the black relay box all good. I dont understand why its not working any more ? The hazards are also not working. Anyone have nay ideas or digrams I can start with. Thanks
Old Mar 11, 2005 | 10:13 AM
virusiidx's Avatar
are you using the correct bulbs for the signals?
Old Mar 11, 2005 | 05:47 PM
94DOHCGsr's Avatar
Default Re: Blinker Stoped Working HELP Plz (exit3k)
if it aint the wrong bulbs, then get a new flasher..about 20 bucks.
Old Mar 11, 2005 | 06:47 PM
B16a-hole!'s Avatar
HAD THE SAME PROB. A WHILE BACK, REPLACED FLASHER AND PROB. WAS SOLVED !!
Old Mar 14, 2005 | 03:49 PM
exit3k's Avatar
Default Re: Blinker Stoped Working HELP Plz (B16a-hole!)
Flasher the black fuse under the driver side. ? I replaced this still same problem. COuld if be wiring ? plz help....
exit3k's Avatar
Also pulled over today. Warning.
Old Mar 14, 2005 | 04:02 PM
onePOINTsix's Avatar
Add blinker fluid
But seriously if you replace the turn signal relay they should start working, if they dont then you have a short to your chassis some where which could be a real PITA
tallguy21
May 17, 2012 04:13 PM
recaroem2
Honda Civic (2001 - 2005)
Dec 11, 2008 11:44 AM
CeReal
Jan 26, 2008 09:55 AM
lsracer27
Jan 28, 2007 11:33 AM
hans stoner
Oct 2, 2006 06:11 AM
