valve cover gasket install...tips for no leaks
Old Mar 11, 2005 | 09:04 AM
dmxsoulja3's Avatar
Default valve cover gasket install...tips for no leaks
Like most things on a Honda the gasket is never enough, I have never done an h22 valve cover, but Honda bond has been my friend for a long time when I had a civic, can someone give me some feedback on the h22 cover, where to use some sealant, etc.
Thanks, J
Old Mar 11, 2005 | 09:42 AM
iakona's Avatar
honda bond in each corner and where the gasket makes a change in direction (i.e.: cam seal, dizzy, cam gears, etc.). no leaks then.
Old Mar 11, 2005 | 09:44 AM
98TypeSH's Avatar
Default Re: (iakona)
yea, he covered it right der. Also make sure the spark plug o-rings are cool. If they are torn or worn replace them.
Old Mar 11, 2005 | 10:39 AM
Matgallis's Avatar
Default Re: (98TypeSH)
I put a thin layer of gasket seal around the whole strip. Hasn't leaked yet
Old Mar 11, 2005 | 02:59 PM
BB4's Avatar
BB4
i jsut put the gasket on and bolted it down, no leaks......
Old Mar 11, 2005 | 03:23 PM
lewdude's Avatar
Default Re: (Matgallis)
yeah, I did the same. I just put it all over the gasket, not the spark plug gaskets but the valve cover gasket. I hope the more the better applies to this application.....
Old Mar 11, 2005 | 03:48 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">honda bond in each corner and where the gasket makes a change in direction (i.e.: cam seal, dizzy, cam gears, etc.). no leaks then.</TD></TR></TABLE>
yep, right in the corners where the oter cam caps meet the head just like B series
Old Mar 11, 2005 | 07:26 PM
matix's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">I put a thin layer of gasket seal around the whole strip. Hasn't leaked yet </TD></TR></TABLE>
I also did this and it works like a charm never had any leaks but this was after reusing it. When it was new i just bolted it up with gasket sealer anywere were it changed direction. Make sure to torque it correctly in the right sequence also.
Old Mar 12, 2005 | 02:19 PM
Fongman's Avatar
Default Re: (matix)
I don't think you want to put them on all around the gasket? I would put them only where the cam are at....
Old Mar 12, 2005 | 07:33 PM
jdmlude_dude's Avatar
Default Re: (Fongman)
honda will place them in the corner, you can get by with that fine. That is how i did mine and around the cam seals as well just for added protection. But some people would coat the entire gasket. I wouldnt like that because it would be a pain to get that crap all over your head and then have to toss the gasket everytime you take off the valve cover. I have taken mine off many times and reused the same gasket. I have only replaced the spark plug ones though because one tore. Now another good sealant is copper spray. I love that stuff!!. Or you can even not use anything on it, just the gasket itself. It is really whatever you want to do.
specbb6
Dec 15, 2011 11:21 PM
squire
Mar 10, 2008 03:40 AM
miksew
13
Oct 20, 2006 05:48 PM
LilGreenMachine
Jun 12, 2004 01:58 PM
FSTRex
Oct 5, 2001 09:07 AM
