"Bobby's Garage Sale"
Old Mar 11, 2005 | 08:32 AM
H8 O ATE's Avatar
Default "Bobby's Garage Sale"
garage getting full and extra cash always helps so...all reasonable offers will be considered..I'll get prices up later.till then you can make your own
B16A Camshafts and cam gears
B16A Heatshield (I'll those in the dirt too!)
Nokya Battery Tie, cluth resivour cover, and fuse box cover (BLING factor of 10)
OEM Radiator fan
Crane's Translucent Dist. cap SI (for use with external coil, not the cheap matrix one)
Tenzo rally type seats, black. No rips, tears, or blemishes. Fully reclinable
2000 Blue Honda Civic Xmod RC
Custom painted, wing holes drilled but wing was removed h34r: (de-riced)
Stage 2 Motor Upgrade
The motors in the Stage 2 upgrade were created for fearless RC racers with insane skills and jedi reflexes. They’re engineered to give you the things you crave most: SPEED, SPEED and SPEED. Just remember to back off the juice on turns, or you’ll eat it hard. Includes a heat sink to keep things chill, and four different 30,000 RPM motors with varying gear configurations for performance and speed.
INCLUDES:
8-Tooth Drift Motor and gearing for maximum torque (white)
9-Tooth Drag Motor and gearing for balanced torque/horsepower (red)
10-Tooth Road Race Motor and gearing for balanced torque/more horsepower (yellow)
11-Tooth Top Speed Motor and gearing for maximum horsepower (blue)
(retail=15.99)
Suspension and Steerign upgrade
Optimize your shocks for touring, road racing, even heads-up dragging with soft, medium and stiff suspension springs, brought to you by Eibach. You’ll minimize wheel chatter and improve handling over any terrain. You’ll also get a set of metal dampers, which give you a smoother, more accurate response system than stock plastic parts. Finally, the included tie rods let you adjust toe-in (camber) of your suspension, which alters your car’s turning abilities. The more turns on a track, the more camber you want. XMODS Custom RC Starter Kit required.
INCLUDES:
4 Soft Suspension Coils (red)
4 Medium Suspension Coils (yellow)
4 Stiff Suspension Coils (blue)
4 Metal Shaft Air Dampers
4 Screws
1 Tie Rod with 1.5 degree toe-in
1 Tie Rod with 3.0 degree toe-in
1 Tie Rod with 4.5 degree toe-in
(retail=7.99)
All-wheel drive upgrade
The elusive Tuner Trifecta — traction, speed and cornering. Now you can have all three by upgrading to four-wheel drive. Less friction and a limited slip differential means ultra-efficient driving and handling. Comes with a tube of XMODS Gear Grease to keep moving parts running smooth and quiet. XMODS Custom RC Starter Kit required.
INCLUDES:
1 Front Center Gear (white)
1 Rear Ball Differential Gear
1 AWD Assembly
1 Pair Matching Rear Swing Arms (red)
1 XMODS Gear Grease
(retial=14.99)
Command logic lights
Other racers are still afraid of the dark, but you can still rule the streets after the sun goes down with this light kit, brought to you by Santeca. Move forward, and the headlights shine. Hit the brakes and your taillights fire up. XMODS Custom RC Starter Kit required.
INCLUDES:
1 LED Headlamp and Taillamp Assembly
4 Screws
(retail=5.99)
Honda Civic Body kit upgrade
These kits come with two sets of genuine Versus bumpers, side skirts and rear wings that let you tune as mild or wild as you want. You also get a tricked out hood and oversized exhaust pipe, along with a custom Sparco controller steering wheel.
(retail=12.99)
Custom 6cell upgrade kit!
bet your friends dont have this on their xmod!
(priceless!)
<FONT COLOR="red">I'm looking for the following items as well, if you have them maybe we can work out a trade, or something</FONT> :shifty:
All Items must be new.
-OEM B18C1 Main seal
-OEM B18C1 Water pump
-OEM B18C1 Oil pump
-OEM B18C1 Camshafts (can be used)
sdr KEL
Northern California (Sales)
13
Nov 2, 2009 11:17 PM
blackzrd
Oct 7, 2008 08:11 AM
nuttybumpo
Honda S2000
17
Jun 4, 2006 06:41 AM
