Upgrade 1st gen b16 to 2nd gen throttle body
For the record the stock MAP sensor wiring on the EF/ED will reach the TB mounted MAP sensor if you pull the wiring out of the loom bundle. No need to extend the wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro »</TD></TR><TR><TD CLASS="quote">For the record the stock MAP sensor wiring on the EF/ED will reach the TB mounted MAP sensor if you pull the wiring out of the loom bundle. No need to extend the wiring. </TD></TR></TABLE>
Good info...
Good info...
I'm running a GM 3bar map. is the hole from the map on the throttle body easy to plug?
EgSalad
Jun 6, 2007 12:12 PM
braindamaged1972
Feb 1, 2007 07:12 AM
Pooper
Oct 16, 2006 09:19 PM
