hyper blink relay trick? diy?
Old Mar 11, 2005 | 02:17 AM
Dc2 Powered's Avatar
Default hyper blink relay trick? diy?
does anyone know the trick so i can adjust the blinker speed?
first off yea i did search and all the threads came out to people flameing..
go ahead flame. i dont give a ****.. but its real anoying when everyone said "search" and when you acually do you get uses thread with just a bunch of ******** who think their "jdm" so they flame on other for **** the ppl do to their OWN CARS..
ok so with that being said i have seen it done and i dont want it to always blink hyper i just want to adjust it so i can mess with my friends and have the hazards going like 50x faster or somthing ..
anyone know how?
btw i dont want to buy a relay from some webpage for like 50 bucks..
i know there is a way to make this DIY for like 5 bucks with some wires and a adjuster ****... i would just like to know how
Old Mar 11, 2005 | 03:09 AM
gotsmokedright2's Avatar
Default Re: hyper blink relay trick? diy? (Dc2 Powered)
cut the black wire at the front corner lights.
i did this when i was a ricer too
Old Mar 11, 2005 | 04:22 AM
Default Re: hyper blink relay trick? diy? (gotsmokedright2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotsmokedright2 &raquo;</TD></TR><TR><TD CLASS="quote">cut the black wire at the front corner lights.
i did this when i was a ricer too </TD></TR></TABLE>
did you take the time to read my Post?
cutting that wire would make it hyper blink non stop..
i want to adjust it so i can set it normaly or as fast as i want.
please read before you post useless replies with dumbass remarks
Old Mar 11, 2005 | 01:20 PM
TTT
Old Mar 11, 2005 | 08:30 PM
calxtreme's Avatar
i have done this before, you will need to buy a potentiometer from radio shack and splice it into the flasher relay. You are essentially replacing one of the resistors inside the relay with a potentiometer(100K pot).
Modified by calxtreme at 6:02 AM 3/12/2005
Old Mar 11, 2005 | 08:32 PM
calxtreme's Avatar
ok, this might help:
http://www.overboost.com/story.asp?id=315
Old Mar 11, 2005 | 08:56 PM
Default Re: (calxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme &raquo;</TD></TR><TR><TD CLASS="quote">i have done this before, you will need to buy a potentiometer from radio shack and splice it into the flasher relay. You are essentially replacing one of the resistors inside the relay with a potentiometer(100K pot).</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme &raquo;</TD></TR><TR><TD CLASS="quote">ok, this might help:
http://www.overboost.com/story.asp?id=315</TD></TR></TABLE>
thx man
Old Mar 11, 2005 | 09:07 PM
calxtreme's Avatar
no prob. Everyone use to refer to:
http://www.andrews.edu/~johnso....html
That site use to provide a lot of honda mods, but it no longer exists.
Maybe you can help renew it by posting up pics and a guide for a DIY. I actually use this mod to slow down my blinkers instead of speeding it up since I am running LEDs.
Old Mar 11, 2005 | 09:21 PM
r3v da t3g's Avatar
Yea Post Instruction When You Do It.
Old Mar 11, 2005 | 09:27 PM
ok i'll try but my friend said he'll give me a new resisitor that makes it hyper blink x100 haha
and one of my other friends knows how to do this better then i cus he's done it before so as soon as i get the chance i'll post pics and a DIY write-up
Old Mar 12, 2005 | 12:45 AM
jdm_cars's Avatar
Default Re: (Dc2 Powered)
dude!!!!! all you gotta do is to put LED 1156 bulbs in your rear tailight turn signals, then all your bulbs will HYPER FLASH! for reals!
you can get your bulbs from http://www.superbrightleds.com buy a pair of 1156 Reds 24LED is what I got install them in your tails and Vola! your turn signals hyperflash!
The reason for this is: the LEDs do not have the correct resistance as the normal Halogen Bulbs, so your turn signals will hyperflash.
Believe me it works and I have this on my car.
Old Mar 12, 2005 | 12:58 AM
Default Re: (jdm_cars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars &raquo;</TD></TR><TR><TD CLASS="quote">dude!!!!! all you gotta do is to put LED 1156 bulbs in your rear tailight turn signals, then all your bulbs will HYPER FLASH! for reals!
Believe me it works and I have this on my car. </TD></TR></TABLE>
hah no disrespect and thx for helping but if you would have read you would know i want to ADJUST IT.. so i have to mess with the resistor and stuff
Old Mar 12, 2005 | 11:24 AM
calxtreme's Avatar
If you take apart the flasher relay, you'll see some resistors, i think you replace R2 with a 100k pot.
Old Mar 12, 2005 | 04:09 PM
jdm_cars's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">
hah no disrespect and thx for helping but if you would have read you would know i want to ADJUST IT.. so i have to mess with the resistor and stuff </TD></TR></TABLE>
Long ago i used to see a few ricers with them hyperflashes, it would flash a few times real fast, then flash a few times slow, looked real cool but other than that, what is the point of having it? Are you just trying to draw attention to yourself?
or do these hyperflashes make you gain 10+ horsepower?
Just kidding, anyway, good luck with the install and please let us all know how it's done. I want to know too. I'm guessing, but this is prob done with some replacement of the blinker relay under the dash by the fusebox area, or some kind of aftermarket device that taps into your blinker signal wires.
Old Mar 12, 2005 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars &raquo;</TD></TR><TR><TD CLASS="quote">Long ago i used to see a few ricers with them hyperflashes, it would flash a few times real fast, then flash a few times slow, looked real cool but other than that, what is the point of having it? Are you just trying to draw attention to yourself?
Just kidding, anyway, good luck with the install and please let us all know how it's done. I want to know too. I'm guessing, but this is prob done with some replacement of the blinker relay under the dash by the fusebox area, or some kind of aftermarket device that taps into your blinker signal wires. </TD></TR></TABLE>
first off
hahha..
yea like this guy saids
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme &raquo;</TD></TR><TR><TD CLASS="quote">If you take apart the flasher relay, you'll see some resistors, i think you replace R2 with a 100k pot.</TD></TR></TABLE>
my friend is giving me one of those..
but i'm also getting another friend to help me solder cus i've never done it before to make a adjuster ****.. i'll take pics and show u guys how it's done!
Poa
Dec 20, 2012 05:40 AM
carsonstory
Sep 22, 2008 08:07 PM
em12nv
Feb 8, 2008 08:30 PM
diM`
Aug 4, 2003 11:58 AM
