Civic HX tranny swap from CVT
Old Mar 10, 2005 | 09:03 PM
bmheck5184's Avatar
Default Civic HX tranny swap from CVT
I searched, but found no definite answer.
What all would I need to do to change out the CVT auto tranny for a different d-series auto tranny?
Would a jdm CVT tranny just bolt up and require nothing else???
Modified by bmheck5184 at 11:27 PM 3/14/2005
Old Mar 10, 2005 | 09:30 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: Civic HX tranny swap from CVT (bmheck5184)
not quite sure here but i'll take a stab at it
You'll probably need a new TCM, flex plate and torque converter. Also probably a new torque converter cover. Thats all I can think of right now.
GL
Old Mar 10, 2005 | 09:34 PM
bmheck5184's Avatar
Default Re: Civic HX tranny swap from CVT (HalfAnP)
would that stuff not come w/ an auto tranny if I bought one?
sorry for the "noob-ish" questions, I have just never dealt w/ auto trannies, much less a CVT
Old Mar 10, 2005 | 10:20 PM
Mike K's Avatar
i think the flexplate would be the same. my main concern would be the engine wiring harness. get one from an EX auto. the cvt and standard auto trannies have different connections and plugs.
torque converter may be different, but i would think that would be included with the transmission assembly.
Old Mar 10, 2005 | 11:06 PM
bmheck5184's Avatar
Default Re: Civic HX tranny swap from CVT (Mike K)
the wiring harness for just the tranny? or the harness for the whole engine bay?
anyone ever done this swap???
Old Mar 11, 2005 | 01:10 AM
bmheck5184's Avatar
bump
Would a DX auto, axles and ecu work?
Would the P2E ECU work?
Old Mar 11, 2005 | 01:08 PM
bmheck5184's Avatar
ttt
Old Mar 11, 2005 | 01:41 PM
DaZman69's Avatar
y would you want to get rid off the cvt and put an auto in there?
Old Mar 11, 2005 | 02:46 PM
bmheck5184's Avatar
Default Re: Civic HX tranny swap from CVT (DaZman69)
the CVT is blown, and they are hella expensive, hence why I am hoping to change to just a regular auto.
Old Mar 11, 2005 | 02:55 PM
bmheck5184's Avatar
another question....will a jdm cvt tranny just bolt up and work correctly?
Old Mar 11, 2005 | 04:10 PM
Mike K's Avatar
i would think the axles are the same.. but i'm not sure.
look in the service manual and see if there's a difference in connections on the wiring harness.
Old Mar 11, 2005 | 07:34 PM
bmheck5184's Avatar
i dont have a service manual for either
Surely someone has done one of these before????
Old Mar 13, 2005 | 10:34 PM
bmheck5184's Avatar
ttt
Old Mar 14, 2005 | 02:41 AM
bmheck5184's Avatar
bump
Old Mar 14, 2005 | 12:11 PM
bmheck5184's Avatar
bump...need to get something done on this car soon...what do you all suggest?
Old Mar 14, 2005 | 05:22 PM
bmheck5184's Avatar
bump...come on, where are the "techies" of Honda-Tech???
Old Mar 14, 2005 | 08:29 PM
bmheck5184's Avatar
anyone?????
Old Mar 14, 2005 | 10:37 PM
bmheck5184's Avatar
going to buy a jdm cvt tranny tomorrow i guess if no one has any input....hope it works
anyone?
Old Mar 15, 2005 | 08:21 AM
bmheck5184's Avatar
bump
Old Mar 15, 2005 | 11:40 AM
bmheck5184's Avatar
please help???
Old Mar 15, 2005 | 12:37 PM
monicle's Avatar
I have a 99ex tranny and torque converter for you. you will need a new ECU for sure.
Old Mar 15, 2005 | 07:20 PM
bmheck5184's Avatar
Default Re: Civic HX tranny swap from CVT (monicle)
do you know what else I would need???
how much?
Old Mar 15, 2005 | 09:24 PM
Civic4less's Avatar
whats up with you throwing "JDM" around?
Anyways... I ran into the same question couple months ago back when I got my HX. The swap is pretty much bolt on except you need an ECU from that Tranny. Because the CVT tranny runs a **** LOAD different. Its nothing like normal everyday transmissions.
Since you know more about Manual transmissions why not just do an auto-manual swap? CVT tranny will run you around 1k+ you can do an auto-manual for around 500$. You'll be satisfied.
I was able to find someone who fixed my hella messed up tranny for just 300$. 6 months later its still running strong. When it breaks i'm doing Auto-Manual swap though.
Old Mar 16, 2005 | 05:55 AM
bmheck5184's Avatar
Default Re: Civic HX tranny swap from CVT (Civic4less)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less &raquo;</TD></TR><TR><TD CLASS="quote">whats up with you throwing "JDM" around?
I was able to find someone who fixed my hella messed up tranny for just 300$. 6 months later its still running strong. When it breaks i'm doing Auto-Manual swap though. </TD></TR></TABLE>
I am not just throwing the word jdm around, there is an engine importer that I found that seperates the CVT trannies and sells them off, therefore, it is a jdm cvt tranny. I was just asking if they were any different than ours.
I have also thought about doing the auto-manual, but in that case I am also not sure what I would need. Yes, I have searched and have the list to do a DX/EX auto-manual, however there is limited info on the hx, and I just want to make sure that it is the same process to switch it over.
So if I can come across a DX auto tranny, and a DX auto ecu than I can just switch those two in for the CVT and the HX ecu?
Old Mar 18, 2005 | 11:59 PM
bmheck5184's Avatar
anyone?
