Stuck Key
Old Mar 10, 2005 | 08:06 PM
TheRoverSyndrome's Avatar
Default Stuck Key
My buddie just got a 94' DX
and it runs great, but the hood wont open and the key is stuck in the ignition, it rotates ok, but it wont come out
thx in advance
Old Mar 10, 2005 | 08:09 PM
B16aDasher's Avatar
Default Re: Stuck Key (TheRoverSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheRoverSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">My buddie just got a 94' DX
thx in advance</TD></TR></TABLE>1.)step on the clutch
2.) rotate key back
3.) pull out
Old Mar 10, 2005 | 08:15 PM
brentmc79's Avatar
Default Re: Stuck Key (B16aDasher)
If its an automatic, make sure its in park before you try to remove the key.
Old Mar 10, 2005 | 09:31 PM
SOHCex20's Avatar
Default Re: Stuck Key (brentmc79)
you probably need to replace your ignition cylinder. Happened to me, had to get it towed because wouldnt come out, wouldnt even start the car. Took it to the honda dealership and had to have a new one made to match the door locks.
Old Mar 11, 2005 | 02:10 PM
its an automatic, and we put the other key in the shift lock, tried it in drive, reverse, neutral and park, the car started in neutral, but the key remains stuck.
Old Mar 12, 2005 | 10:26 AM
well a fat lotta good you guys are
Old Mar 12, 2005 | 11:35 AM
adaml2nv's Avatar
Default Re: (TheRoverSyndrome)
is the key bent? it only take alittle bend to make the key stuck. that happened to my uncles nissan altima.
i just kept on pulling and wiggling, it finally came out after 15 minutes .
Old Mar 12, 2005 | 03:34 PM
JarvisW's Avatar
Sol to Sol
Default Re: (adaml2nv)
I got my key stuck in the drivers door once(93 Del Sol). It got stuck after unlocking the door, but stopped about 1/8 turn from being able to get it out.
I thought I was going to have to break it off, cause it couldnt move, and I couldnt leave the car sitting in that area, while I ran home and back (about an hour round trip) with another key!
Anyway, when I went to try and break it off in the lock, it finnaly turned and I was able to get it out of the door. Then I nerviously used it to start the car. Had no problems with it sence tho.
BTW, I changed to another key, and put graphite on all the locks sence then!
Old Mar 13, 2005 | 01:53 PM
hmm... i dont think that the key is bent
ill give that graphite idea a try
minguswooten
Honda Civic (2001 - 2005)
Oct 8, 2021 07:46 AM
daniel reich
Acura TL, RL & ZDX
Sep 13, 2017 03:37 PM
FTNW
May 27, 2012 12:14 AM
drew_kousk
Oct 4, 2010 05:57 PM
Easyslider01
15
Dec 30, 2006 11:57 AM
