90 Integra Halo Headlights help
I just bought halo headlights off of a friend and all of the halos work on the passenger side but only 1 did on the drivers side, now none work on the drives side. I checked the connections and i connected power straight to them and they didn't turn on. Are the halo's blown, if they are how can i replace them. Thanks
try grabbing a dvom and ohming the actual halo leads out... we had the same problem with my roomate's m3... three out of the 4 halo's worked, and we sent reference voltage thru each one of the halo light leads, and it ended up just being a bad connection. Your gunna have to figure out how to take the front cover off so you can open up the back...so there is a bit of work involved...and i'm not sure how difficult it is for tegs. good luck.
mrJDM_DB8
Oct 1, 2008 04:30 PM
freeflyinrider
Dec 5, 2007 07:04 PM
