Questions about B20 Swap setup, Parts etc..
Old Mar 10, 2005 | 06:00 PM
JMod's Avatar
Default Questions about B20 Swap setup, Parts etc..
I'm running a stock b20b bottom end with a gsr head w/ stock gsr cams. I'm going to be running an obd2-obd1 conversion harness. I need some suggestions and some help. This is in a 96' Hatch btw. 1st off, can I reuse my distributor off the single cam? Can I use the stock b20b injectors? And can the sohc alternator be used as well?
The only parts I need now is a tranny with clutch/flywheel, and the motor mounts. I have the shift linkage and everything else. Sound like i'm missin anything?
Old Mar 10, 2005 | 06:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Questions about B20 Swap setup, Parts etc.. (JMod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMod &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a stock b20b bottom end with a gsr head w/ stock gsr cams. I'm going to be running an obd2-obd1 conversion harness. I need some suggestions and some help. This is in a 96' Hatch btw.
1st off, can I reuse my distributor off the single cam? NO
Can I use the stock b20b injectors? YES
And can the sohc alternator be used as well? NO
The only parts I need now is a tranny with clutch/flywheel, and the motor mounts. I have the shift linkage and everything else. Sound like i'm missin anything?</TD></TR></TABLE>
less some fluids and a throttle cable.
lcsej1
Jan 17, 2009 07:01 PM
jdm92teg
Dec 6, 2004 08:31 AM
gsrfrancisco
Jul 8, 2004 09:05 PM
arete213
Nov 14, 2001 04:45 AM
