B16 running really rich?
Old Mar 10, 2005 | 05:36 PM
blackmagicCRX's Avatar
Default B16 running really rich?
I have already checked the O2 sensors, set the idle the correct way, no vacuum leaks. All 4 plugs are black. Gas mileage sucks, Smells like raw fuel the whole time driving. I really can't figure this out and it is eating at my nerves. Help!!!
Old Mar 10, 2005 | 05:46 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: B16 running really rich? (blackmagicCRX)
are the o2s wired like this?:
Originally the round plug was wired to C16,
If it is hooked to c8,it is wired backwards and will run like crap..
Old Mar 10, 2005 | 05:48 PM
Default Re: B16 running really rich? (88DXCRX)
Yeah they are wired right. How are u suppose to check fuel pressure?
Old Mar 10, 2005 | 05:52 PM
88DXCRX's Avatar
I have the b&m gauge on the fuel filter..
Otherwise,you need an adapter/gauge that bolts into the service bolt.
Sizes listed here:
https://honda-tech.com/zerothread?id=1171554
Old Mar 10, 2005 | 07:01 PM
IronOutlawz's Avatar
check the map sensor, mine was the same. bad gas milage and smelled bad.
Old Mar 10, 2005 | 10:59 PM
efboy's Avatar
Default Re: B16 running really rich? (IronOutlawz)
how can u check the map sensor and know ?? just wondering
i think mine has the same problem...
Old Mar 12, 2005 | 10:00 PM
Default Re: B16 running really rich? (efboy)
How do you check the map sensor to see if it is bad?
skylerreniger
Dec 1, 2012 07:04 PM
EGknoxx
Sep 18, 2008 05:08 PM
blackmagicCRX
Dec 13, 2005 11:21 PM
93c1sol
Sep 8, 2005 11:06 AM
burgerbuddy
11
Aug 7, 2005 05:54 PM
