help!@#$
Old Mar 10, 2005 | 02:07 PM
irtrueno's Avatar
Default help!@#$
i got myself a pos 89 crx w/ 92 integra ls motor. the car has lots of problems, motor in particular.
is it a better option to get the overbore on the engine and replace all those parts or get something else? am not sure what to do.
heeeelp.
Old Mar 10, 2005 | 02:20 PM
Magick211's Avatar
Default Re: help!@#$ (irtrueno)
whats wrong with the engine that makes u want to rebuild it?
Even if you do have to rebuild it you dont necisarally have to bore out the cylinders if everything is within specs.
Old Mar 10, 2005 | 04:12 PM
h22_cx_hatch's Avatar
try figuring out whats wrong specifically
Old Mar 10, 2005 | 08:21 PM
EJ2-Fluffy's Avatar
try figuring out whats wrong before doing nething else.
Old Mar 14, 2005 | 08:39 AM
irtrueno's Avatar
Default Re: help!@#$ (hndacrx2)
the engine has millions of miles on it and the piston rings are all fd up so it burns oil. am assuming the engine needs to be rebored etc cause the cylinder walls are egg shaped and no good.
i just have no idea where to start of how much this money pit will be.
Old Mar 14, 2005 | 08:46 AM
Filthy Focker!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irtrueno &raquo;</TD></TR><TR><TD CLASS="quote">am assuming the engine needs to be rebored etc cause the cylinder walls are egg shaped and no good.
i just have no idea where to start of how much this money pit will be.</TD></TR></TABLE>
If that is the case. Then it will be cheaper imho to swap the engine.... Rebuilding an engine can be very expensive (machine shop time + new parts) and labor intensive. Edit: THat's if the car is worth it. Sometimes buying another car is a better approach. If the engine is this bad, then maybe the trans is shot too.
fs
Old Mar 14, 2005 | 11:39 AM
NikoZai's Avatar
Default Re: help!@#$ (filthy_shovel)
I would buy another engine as well. Beats dealing with bad internals.
hmotorsonline.com
When you post that your wiring is screwed up: rywire.com
ej2civic
Nov 6, 2012 07:20 PM
brodyl05
Mar 13, 2007 02:12 PM
kslimm0714
May 8, 2006 02:51 PM
vize versa
Sep 22, 2005 06:55 PM
