Suggestion about Spoon N1 B-pipe??
Old Mar 10, 2005 | 12:14 PM
xla301's Avatar
Default Suggestion about Spoon N1 B-pipe??
Need some advice for the diameter of the B-pipe!! I got a Spoon N1 muffler in hand and I need to custom build a B-pipe, so just need some ideas about what diameter I should use??? And I don't want the N1 to be too loud and I know the only way is to control the size of the B-pipe....so please suggest??
Old Mar 10, 2005 | 02:59 PM
Travis10's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (xla301)
im still kind of new, is the b-pipe the pipe that connects the muffler to the cat.?
Old Mar 10, 2005 | 03:33 PM
xla301's Avatar
yes,that's right. From the cat to muffler.
Old Mar 10, 2005 | 03:34 PM
B2FiNiTY's Avatar
Why don't you get a spoon or t1r b-pipe?
Old Mar 10, 2005 | 04:14 PM
billybaggio
Guest
Posts: n/a
Default Re: Suggestion about Spoon N1 B-pipe?? (B2FiNiTY)
yes thats what im using, Spoon B-pipe, and it sounds deep and nice!!. and it comes with rasenator so it quiets down the sound already. custom piping are always straight and makes it louder
anyways, the Spoon B-pipe should be 2.38in in size
Old Mar 10, 2005 | 04:27 PM
jetydosa's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xla301 &raquo;</TD></TR><TR><TD CLASS="quote"> And I don't want the N1 to be too loud</TD></TR></TABLE>
LOL!
Old Mar 10, 2005 | 04:28 PM
B2FiNiTY's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (billybaggio)
custom piping is not always just straight. That is what custom is all about. You can get resonators made or decide not to do them at all.
Old Mar 10, 2005 | 07:49 PM
xla301's Avatar
can they custom made a pipe exactly the same as the Spoon B pipe? In that case, the price will cut down a lot. Also, the muffler shop tell me for 2.38" pipe only comes in Aluminum. If I choose Stainless Steel then the pipe will be 2.25" so is that true and Will that make a lot of different? Thx
Old Mar 10, 2005 | 09:24 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xla301 &raquo;</TD></TR><TR><TD CLASS="quote">can they custom made a pipe exactly the same as the Spoon B pipe? In that case, the price will cut down a lot.</TD></TR></TABLE>
LOL I guess you haven't priced out having 409SS pipe mandrel bent, SS resonator and TIG welded up with OEM type SS flanges. You'll end up spending just as much or more than a nicer readily available B pipe replacement like a T1R. I'd suggest just getting a T1R B pipe.
BTW If you were to make a Custom B pipe I'd go with 2.5" pipe over 2.25" any day.
Old Mar 11, 2005 | 12:01 AM
.water's Avatar
if ur getting T1R b-pipe there are bottle neck at the flange..(i know web-site says no bottle neck.i e-mailed them)
T1R 63mm(2.5inch) Power Exhaust comes with B-pipe that has no bottle neck at the flange
Spoon b-pipe? keep the money man..check out kteller for custom pipe too
Old Mar 11, 2005 | 01:08 AM
igyloo's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (Chris DC2)
the spoon b-pipe is a work of art though...perfect welds and bends
it's also pretty lightweight
Old Mar 11, 2005 | 02:47 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Spoon b-pipe? keep the money man..</TD></TR></TABLE>
Have you seen a Spoon b pipe in person?
If not, it's quite asinine to comment on it, having no first hand experience with it.
If I had to do it again, I'd still buy the Spoon b pipe over both T1R and KTeller.
My $0.02.
Old Mar 11, 2005 | 05:09 AM
RedR's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (Reid)
I have a spoon b-pipe and so does a friend of mine, and after a few hundred miles both started to rattle.
It does have a bottleneck on the connection to the muffler.
Old Mar 11, 2005 | 06:27 AM
billybaggio
Guest
Posts: n/a
Default Re: Suggestion about Spoon N1 B-pipe?? (RedR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedR &raquo;</TD></TR><TR><TD CLASS="quote">I have a spoon b-pipe and so does a friend of mine, and after a few hundred miles both started to rattle. </TD></TR></TABLE>
i've been having mine on for almost two years, and it never rattled
who installed your B-pipe?? Spoon B-pipe is a good piece man!! first hand experience.
Old Mar 11, 2005 | 08:16 AM
igyloo's Avatar
sounds like installer error
Old Mar 11, 2005 | 09:40 AM
Mike M's Avatar
Founding Member
I'm not suprised, from what I have been told they have been having problems with their resonators for awhile.
Old Mar 11, 2005 | 09:43 AM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">if ur getting T1R b-pipe there are bottle neck at the flange..(i know web-site says no bottle neck.i e-mailed them)
Honestly 99% of the people worrying about "Bottlenecks" might as well worry about the sky falling too. On something like the T1R we aren't talking about a True bottleneck which would be if you had a pipe that went from 2.5" down to say 2.25" but the 2.25" section is longer than say an inch (like tanabes which have about 5-7" of 2" pipe) The T1R and a few others out there "Neck Down" so they can use oem type flanges which is a MUST if you are making a B pipe or Axleback that is interchangeable with oem parts.
Old Mar 11, 2005 | 10:00 AM
RedR's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (igyloo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igyloo &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like installer error </TD></TR></TABLE>
Sure it takes a lot of science to install a b-pipe
Old Mar 11, 2005 | 12:31 PM
R.S.'s Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly 99% of the people worrying about "Bottlenecks" might as well worry about the sky falling too. On something like the T1R we aren't talking about a True bottleneck which would be if you had a pipe that went from 2.5" down to say 2.25" but the 2.25" section is longer than say an inch (like tanabes which have about 5-7" of 2" pipe) The T1R and a few others out there "Neck Down" so they can use oem type flanges which is a MUST if you are making a B pipe or Axleback that is interchangeable with oem parts.</TD></TR></TABLE>
so the bottle neck on the t1r/spoon b-pipe and spoon axle back, doesn't effect anything?
i have a t1r b-pipe and spoon n1 axle back....very high quality pieces, by the way...
Old Mar 11, 2005 | 01:06 PM
.water's Avatar
Default Re: Suggestion about Spoon N1 B-pipe?? (R-Spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Spec &raquo;</TD></TR><TR><TD CLASS="quote">
i have a t1r b-pipe and spoon n1 axle back....very high quality pieces, by the way... </TD></TR></TABLE>
T1R(2.5-2.25) -&gt; N1 2.38 soemthing..so its like big small big again
Old Mar 11, 2005 | 01:08 PM
Mike M's Avatar
Founding Member
It's not a "Bottle neck" (I really don't like that term) it simply necks down for less than an inch to mate to an oem type flange at the cat and at the axleback, everywhere else it is 63mm. I'd say at least 75% of the people using that system are not at a point where such a small change would make any significant difference in power and if it would they should probably run something larger that can flow even more like a 3" or 70mm exhaust. Even then I can't see it causing more than 1-2 hp Max difference in those 25% it could affect. (BTW The 25% I would refer too are either FI or have a Ton of NA upgrades including very high comp, big cams etc)
::MYCORD::
Nov 24, 2005 09:03 AM
R rated
Sep 23, 2003 04:59 AM
SixPAK
Mar 5, 2003 09:29 PM
skafia
Aug 7, 2002 02:49 PM
J'sDC2R
Jul 26, 2002 02:04 AM
