USDM vs JDM swaps & differences
Old Mar 10, 2005 | 10:59 AM
Takumi Fujiwara's Avatar
Default USDM vs JDM swaps & differences
One thing I've confirmed is that JDM starter is different. I assume I can swap this out for use with my flywheel that's made for the USDM.
Anything else different besides compression and some sensors that the USDM uses?
Axles? distributor? etc...
Old Mar 10, 2005 | 12:26 PM
DvD3's Avatar
B A N N E D
Default Re: USDM vs JDM swaps & differences (Takumi Fujiwara)
jdm has more hp, check motor sites ull see for example jdm b18c1 is 180hp and usdm is 170hp. also itr's r 200hp in japland and usdm packs 195hp.
Old Mar 10, 2005 | 01:11 PM
Default Re: USDM vs JDM swaps & differences (DvD3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DvD3 &raquo;</TD></TR><TR><TD CLASS="quote">jdm has more hp, check motor sites ull see for example jdm b18c1 is 180hp and usdm is 170hp. also itr's r 200hp in japland and usdm packs 195hp.</TD></TR></TABLE>
Sorry, I should clarify, I meant physical differences... I may be picking up just the long block, I want to make sure all the USDM stuff on my current integra will be compatible... and since I already have a USDM flywheel, I know it won't work with the JDM starter...
Old Mar 10, 2005 | 09:33 PM
So far it looks as though axles are interchangeable. i'm assume the starters are interchangeable.
Anything else that differs physically, or interchangeably (is that a word?)?
Old Mar 10, 2005 | 10:17 PM
Slain's Avatar
Just little things are different. some sensors by the tb and intake manifold might be different they were on my jdm itr head. compared to my us b17
Old Mar 10, 2005 | 10:18 PM
old_school_dohcvtec's Avatar
appearance wise you'll notice by looking at JDM engines is that the VTEC sign is bigger then the DOHC sign and US engines have the DOHC sign bigger then the VTEC sign.
check it out.
Old Mar 10, 2005 | 10:20 PM
Slain's Avatar
lol i used to have friends that would argue there wasnt a difference in the valve covers lol
Old Mar 11, 2005 | 01:42 AM
Default Re: (Slain)
anyone know what parts are compatible/incompatible between JDM & USDM?
Old Mar 11, 2005 | 07:06 AM
DragnDriftphil's Avatar
Default Re: (Takumi Fujiwara)
what swap are you refering to?
Old Mar 11, 2005 | 08:04 AM
IggyBcool's Avatar
the only really difference iv noticed between them is the jdm's have a slightly higher compression not much but very little difference. also its made in "Japan" and since its made in "Japan" everyone just has to ahve one
i_HeArT_EgS
15
Jan 19, 2006 06:31 PM
1990hondaHF
Jul 29, 2005 09:22 PM
SlipoftheCondom
Nov 26, 2002 09:08 PM
JKim0901
Dec 22, 2001 11:52 AM
