Preflow vs postflow?
Old Mar 10, 2005 | 10:26 AM
underpressure02's Avatar
Default Preflow vs postflow?
What exactly does preflow and post flow do? I was reading through my book and it said for every 10 amps or so you want such and such time in the post flow.
I originally had my welder set to .5 sec of preflow and 10 seconds of postflow but it seemed like I was wasting a ton of gas for nothing.
What is the purpose of having the gas start before the arc starts then having it run after the arc has ended?
Old Mar 10, 2005 | 10:40 AM
david@didrace.com's Avatar
Default Re: Preflow vs postflow? (underpressure02)
Preflow - Purges the gas lines and protects the weld pool from the very start.
Postflow - Protects and cools the weld.
Old Mar 10, 2005 | 10:43 AM
Default Re: Preflow vs postflow? (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Preflow - Purges the gas lines and protects the weld pool from the very start.
Postflow - Protects and cools the weld.</TD></TR></TABLE>
So do you normally have the preflow set for a very short period of time?
When you say protects the weld what do you mean? I thought it cooled the weld but did not want to post that and get flamed.
Old Mar 10, 2005 | 10:46 AM
Usually you only need the preflow on for a second unless more is required by code. Postflow I keep around 7 seconds. Postflow protects the weld by making sure oxygen and other gases don't touch the weld until it is fully solidified. Some codes require you to keep on the postflow for a certain period of time.
Old Mar 10, 2005 | 07:52 PM
Engloid's Avatar
OG Fabricator
I agree with Backpurge.
However, I figure you really don't need any prepurge, but if you do, half a second works fine. Many machines don't even have the option. Mine does, and I don't often use it. If I do, I set it so low I can't tell it's working anyway...dunno why I bother.
anyway, it's useless.
Jmumblez2001
Mar 16, 2008 01:14 PM
menappi
Jun 21, 2006 04:01 PM
LvN
19
Jun 8, 2006 06:58 AM
rice a roni
Welding / Fabrication
21
Apr 30, 2006 12:58 PM
SiMateoAko
16
Aug 17, 2005 05:35 AM
