Will Zeal b6 for eg/dc fit ek's???if not what is needed???
I can get an excellent deal on some zeal b6 for the eg/dc chassis....I want to put them on a 96 civic coupe...Will the fronts/rears fit??...can i use ITR rear control arms for the rear??? what is needed on the fronts to make them work???
Please help i would hate to pass up this deal
thanks
thanks
* B A N N E D *
Fits fine.
Just need a few washers for the rear lca's b/c the eg/dc fork(mounting bracket) is slightly wider.
if its a jdm itr style rear shock, you need to swap your rear subframe...and use an ITR one....then u proceed to use jdm itr rear lca's and youll be ****** GANGSTER! excuse my language but there is an ek that has done this in the appearance and cosmetic..and i wet mypants....it was beautiful!
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo »</TD></TR><TR><TD CLASS="quote">if its a jdm itr style rear shock, you need to swap your rear subframe...and use an ITR one....then u proceed to use jdm itr rear lca's and youll be ****** GANGSTER! excuse my language but there is an ek that has done this in the appearance and cosmetic..and i wet mypants....it was beautiful!
Yes that **** was nice as ****.
</TD></TR></TABLE>Yes that **** was nice as ****.
Pay Zeal 100 or so for each lower portion of the damper.....to have it switched over to the fork type found on the EK.....
then sell EG/DC lower portion as exotic metal JDM ***** on eGay.....
sk8shorty012
31
Mar 9, 2011 10:24 AM
liquid:cooled
13
Mar 19, 2007 08:49 PM
