any decent LS builds out there?
Old Mar 10, 2005 | 07:54 AM
AllaBlurDA's Avatar
Default any decent LS builds out there?
Yes I did use the search button but could find any useful build info...
so on that note I have a daily driver that i wanna get some decent power out of, I already own a turbo built LS and like having no vtec so don't say slap on a vtec head PLEASE, so anyone have any good power build with a LS.
I was thinking type-r pistons balance and blueprinted, and have the good folks of RED ZONE hook it up with a port job and a blox mani and a set of crower NA cams
anything else anyone can recommend?
Old Mar 10, 2005 | 07:57 AM
erebunicrx's Avatar
look for nonvtecallmotor and hybridvtec
Old Mar 10, 2005 | 08:11 AM
AllaBlurDA's Avatar
Default Re: (erebunicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx &raquo;</TD></TR><TR><TD CLASS="quote">look for nonvtecallmotor and hybridvtec</TD></TR></TABLE>
thanks nonvtecallmotor has a sweet setup a little more than what im looking for but easy to take a few steps back from his setup and see what it puts me.
couldnt find anything under hybridvtec
anyone else got any good stuff? im thinking low 13s not fast at all considering but just some guts for fun windy roads on the weekends
Old Mar 10, 2005 | 08:18 AM
erebunicrx's Avatar
Default Re: (AllaBlurDA)
https://honda-tech.com/zerothread?id=1124823
Old Mar 10, 2005 | 08:47 AM
AllaBlurDA's Avatar
sweet his build is more what im looking for hehe
do you know how his car idles? i live in a city that pops down on hondas and a loppy idle won't cut it around here
Old Mar 10, 2005 | 08:53 AM
erebunicrx's Avatar
404's tend to have a limpy idle around 750-900. up the idle and you should have no problem
Old Mar 10, 2005 | 09:18 AM
AllaBlurDA's Avatar
so jumping the idle to 1100-1200 should solve any rough idle?
Old Mar 10, 2005 | 09:22 AM
dohcter g's Avatar
Look in my garage for my old set-up! I dynoed around 175whp.
Old Mar 14, 2005 | 09:20 AM
AllaBlurDA's Avatar
Default Re: (dohcter g)
good stuff man!
Old Mar 14, 2005 | 09:44 AM
Grand's Avatar
i am just finishing up one man ill post my setup
Old Mar 14, 2005 | 10:11 AM
Grand's Avatar
heres mine man im hoping for 180whp
b18a1 ls
crower 404 cams
ported and polished head(pro done)
7deg valve job
head mill .40
shotpeened rods
arp rod bolts
ard head studs
81.5mm p30 pistons
js racing short ram intake
dc 4-1 ceramic header
aem power pulleys
aem 5 bolt cam gears
uberdata ecu tune
accel 290cc injectors
str block guard
unorthodox racing crank pulley
msd blaster 2 coil and adapter towers(yes i converted to external coil cap)
nology hotwires and silverstone spark plugs
mandrel bent 2 1/4 inch exhaut with hayame muffler and magnaflow cat
aem fuel rail
b&m fuel pressure regulator
70mm throttle body
port matched intake manifold
it has an act 6puck clutch disc
and ys1 lsd cable tranny
things i just remembered
total seal rings
balanced and blueprinted bottom end
hondata intake manifold gasket
copper seal header gasket
flat faced crower valves
crower valve springs and retainers
Old Mar 17, 2005 | 06:44 AM
AllaBlurDA's Avatar
Default Re: (LG_R32)
sounds pretty good
id lose the aem cam gears tho even the 5 bolt ones scare me lol
Old Mar 17, 2005 | 07:18 AM
arw321's Avatar
Search for my setup. I'm too lazy to post it.
Old Mar 17, 2005 | 09:04 AM
Grand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllaBlurDA &raquo;</TD></TR><TR><TD CLASS="quote">sounds pretty good
id lose the aem cam gears tho even the 5 bolt ones scare me lol </TD></TR></TABLE>
well what would you suggest ive used aem 3bolts before and didnt have any problems
Old Mar 17, 2005 | 11:01 AM
hybrid_vtec's Avatar
If you already have AEM's then keep them otherwise I suggest the 6-bolts from JG Engine Dynamics. You can get a pair for $130-140 shipped
Old Mar 17, 2005 | 01:16 PM
allmotorej8's Avatar
Default Re: (hybrid_vtec)
sup im from the bay area, building up a all motor ls
redzone tunned my car, its a good shop
i think itr comp is a lil too low
get p30
with stock bottom and built head i got 160whp
im hoping for 200 whp after the os p30 are installed with anr headers, got my block back from the shop after being hontanked. Just need the lil parts like arp rod bolts, balancing my crank, honing, complete gasket kit, shoppen my ls rods, boring my motor 81.25 and etc.
the compression is set around mid-low 11's and should be fine on 91oct
with good tunning it'll be fine
if you want, u can check out my set up as is right now on my car, i got 404's and a built head on my ej8 right now, PULLS HARD
props for nonvtec builts
Old Mar 17, 2005 | 05:48 PM
Default Re: (aLLmTreK)
Sounds good! Keep us up to date.
Old Mar 20, 2005 | 01:52 AM
91ls-v's Avatar
anybody try the exospeed race ls cams yet?
i'm thinking about trying it
also do you guys think gsr valve train will work for a b18a motor
Old Mar 20, 2005 | 08:30 AM
vart's Avatar
Default Re: (91ls-v)
or u can buy my 404s
Old Mar 20, 2005 | 08:38 AM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">anybody try the exospeed race ls cams yet?
also do you guys think gsr valve train will work for a b18a motor</TD></TR></TABLE>
I'm going to be using GSR outer springs with some after market inner springs I found on http://www.inlinefour.com There $80 and stiffer. They should hold up against my 404's.
Old Mar 20, 2005 | 08:55 AM
dohcter g's Avatar
Default Re: (91' LS-VTEC)
Got mine running yesterday. Let ya know what I dyno. All motor LS in the 12's, I cant wait!
Old Mar 20, 2005 | 04:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">Got mine running yesterday. Let ya know what I dyno. All motor LS in the 12's, I cant wait!</TD></TR></TABLE>
Be sure to keep me informed! Your new build interests me!
Old Mar 22, 2005 | 06:47 AM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Be sure to keep me informed! Your new build interests me! </TD></TR></TABLE>
I will. Have you done a Comp test on you engine. If so what are your numbers?
Old Mar 22, 2005 | 09:30 AM
I will. Have you done a Comp test on you engine. If so what are your numbers?</TD></TR></TABLE>
I'll have to do that sometime this week and get it too you! Last I remember, think it was between 220-230 across the board.
Old Mar 29, 2005 | 04:41 PM
Grand's Avatar
welll guys im at the dyno right know preparing for a run and some tuning
