is a f22 alternator compatible with h22a braket?
Old Mar 10, 2005 | 02:08 AM
superturboprelude's Avatar
Default is a f22 alternator compatible with h22a braket?
Old Mar 10, 2005 | 04:30 AM
Sam1am26's Avatar
Default Re: is a f22 alternator compatible with h22a braket? (superjunprelude)
Yes... it will bolt to the alternator bracket... But I think the belts are different...
Old Mar 10, 2005 | 05:18 AM
Sam1am26's Avatar
Default Re: is a f22 alternator compatible with h22a braket? (Sam1am26)
I just compared an h22/23 alternator to an f23 and the number of ribs on the alternator pulley are different... I don't know if the f22 has the same number of ribs because i don't have one to look at, but even if it does you could just switch the alternator pulley to match whatever crank pulley you are using...
Old Mar 11, 2005 | 07:03 PM
thanks dude
Old Mar 12, 2005 | 05:19 PM
prelittlelude's Avatar
yeah they bolt up but the f22 has fewer ribs and a bit bigger pully.
Old Mar 18, 2005 | 07:45 AM
4doorH22's Avatar
Default Re: is a f22 alternator compatible with h22a braket? (prelittlelude)
I have the same question. I think the H22 alternator is dying and want to swap in the F22 alternator. I haven't pulled either alternator yet, but is it easy enough to pull the F22 alternator pulley off the F22 alternator and put it on the H22 alternator? (Or get a thinner belt?)
Old Mar 18, 2005 | 04:25 PM
PrettyLude's Avatar
Default Re: is a f22 alternator compatible with h22a braket? (4doorH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorH22 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same question. I think the H22 alternator is dying and want to swap in the F22 alternator. I haven't pulled either alternator yet, but is it easy enough to pull the F22 alternator pulley off the F22 alternator and put it on the H22 alternator? (Or get a thinner belt?)</TD></TR></TABLE>
this is where an impact gun comes handy, do not try and hold that pulley with your hands when you are shutting off that pulley
Old Mar 18, 2005 | 05:14 PM
v4lu3s's Avatar
RTFM
same alternator, different pulley, not jstu ribs but also diameter. i have an accord alternator on my h22 right now works fine iwth the right length belt.
lude98SH
Apr 2, 2009 03:13 PM
bubxba
Jun 20, 2008 05:23 AM
Turbo O
Mar 30, 2006 09:19 AM
ProjectLudeSiR
Sep 2, 2004 11:01 AM
