Skunk2 Coils: Which sleeve goes where?
There should be part numbers on your coils....i have an 94+ integ..dont know if there much diff from the 94- integs...but on the springs itself..they should have numbers...ending in .06.....08....or .10......those are spring rates..the higher number always goes in the front....
so basically say you have 4 coils..2 of them say .06 at the end and 2 of them say .08....the .08 would be in the front and the .06's in the rear...its as simple as that
JUST THE SLEEVE PART. The spring perch if you will. The metal threaded pipe. Call it what you will, I need to know what one goes in the front, and what one goes in the rear. 2 sleeves have a little extra ring-thing at the bottom.
do they have have 2 rings at the bottom? They're all suppose to have 2 rings at the bottom, and i don't think it matter which ones goes where it's universal i believe, just the springs aren't (cause of the spring rates)
blk_dc
Suspension & Brakes
Mar 25, 2011 11:54 PM
