i have two different front LCAs
Old Mar 9, 2005 | 06:34 PM
ek_will's Avatar
Default i have two different front LCAs
I noticed i have two different LCAs on one has sway bar holes and one does not, my question is will this affect anything? i noticed the driver side which has the sway bar holes the castor is really off i did recently drop the car.
I have the correct LCA but im not sure if its worth it to put it on if it isnt affecting anything.
Old Mar 10, 2005 | 03:49 AM
ek_will's Avatar
Default Re: i have two different front LCAs (dash_0n)
anyone?
Old Mar 10, 2005 | 04:53 AM
monicle's Avatar
wont affect anything as long as you dont try putting a sway on the front later.
Old Mar 10, 2005 | 05:52 AM
Ministry's Avatar
haha your LCAs are from two different cars.
mine dont match either. I needed to replace an LCA and I used one from a different trim level EG because it was free and my car already looks like ***. functionally, its the same. I wouldn't worry about it.
EDIT: oh **** you said front lower control arms. I was talking about rear LCAs. if the dimensions are the same (length, distance between the holes, etc.)I still think it should be ok. if you're really worried you could take them off and compare.
Old Mar 10, 2005 | 07:33 PM
ek_will's Avatar
Default Re: i have two different front LCAs (dreamer)
from glancing under the car it looks pretty weird, looks 5th gen'ish is it possible a 92-95 LCA would fit on a 96-00 ?
sinfulj32
Suspension & Brakes
Jul 23, 2006 03:30 PM
SweetChin
Apr 15, 2005 09:28 AM
spock_rocker
May 23, 2004 06:43 AM
clm
10
Aug 23, 2003 01:35 PM
EGO
15
Feb 4, 2003 07:15 PM
