matching numbers
Not exactly. There's an engine serial # stamped onto a flat spot on the side of the block, near the flywheel.
Beginning in '96(?) all engines & transmissions ALSO had to carry a metal tag stamped with the VIN, which is usually riveted into the block towards the bottom near the oil pan.
