H22a full turbo kit new and ready to ship
After buying my new s2000 i have decided to give up on my modding my prelude. So i have a brand new vecco turbo kit for sale. This kit was never used just taken out of the box and mounted to the car for fab work. I spent over 300 dollors on having a shop build my down pipe. Also spnt a extra 400 dollors and got a huge fmic from vecco when i got this kit. It cost me over 2000 dollors last year. I have close to 2600 total in the whole kit not including labor charges. If i still have my new aem fuel rail when i sell this kit i will throw it in for free. Im asking 1550 shipped for it all. I also have a greddy turbo timer that i found that i will throw in. You might need to do some fab work to get this kit to fit perfect. Again this is a brand new kit i never put a single mile on it. Below are the details directly from vecco and a stock photo of what the kit looks like. Any questions please email me at brettlysaysthis@aol.com and check out my feedback on ebay my user name is brettlysaysthis
New Turbo Kit Honda Prelude H22a This kit only uses top quality parts at a very affordable price. Everything is brand new never used. Everything comes just as pictured - polished, brand new never used! Build your own kit and save! Add up to 150HP with this kit!
Brand New Garret/Turbonetics T-3 Turbocharger, polished to a mirror shine
This turbo is designed to be a perfect match to the DOHC honda motors which promotes fast spool up and top end power. Very little turbo lag with turbo. Turbo has an exhaust A/R of .48 and a 60 trim T3 compressor. Turbo is good for 340 Hp.
Stainless turbo header
Quality polished tubular style manifold made of 304 stainless steel
You can keep power stearing and AC pump.
Turbonetics 35mm Evolution Wastegate
Will support more horsepower then you could throw at it!
Maximum accuracy (one spring included).
Comes with extra flange for dump tube, 2 gaskets and all necesarry hardware.
Mandrel bent 304 stainless steel intercooler and turbo pipes
Includes silicone couplings with clamps, nitril reducer and elbows
These charge pipes are stainless steel and will never rust or corrode like steel and aluminum, and are easily brushed or polished for a show quality look. Used by all the top racers!
Turbo intake Filter
Oil supply and drain kit
3'-3AN stainless steel oil supply
1'-5/8" high temp oil return
includes all necessary hardware & fittings
Stage 2 Blow off Valve
Extremely loud blow of valve.
Steel downpipe
Steel downpipe kit (Weld to fit ANY setup), Includes mandrel bent piping!
External Wastegate Block-off Flange (may vary from picture)
Notes: Other items you may need to make this a complete kit are: FMU and/or injectors/fuel pump, missing link etc. This kit is designed for the DIY builder, slight fitting may be necessary depending on your model. Piping will have to be deburred and cleaned before installation. If you are unfamiliar with a turbo system install we recommend professional installation. Additional part can also be purchased directly from us if needed also. Every installation will vary.
Will fit the following models
94-96 Honda Prelude VTEC 2.2L DOHC VTEC I-4 H22A1
97-98 Honda Prelude 2.2L DOHC VTEC I-4 H22A4
97-01 Honda Prelude Type S (JDM) 2.2L DOHC VTEC I-4 H22A
99-01 Honda Prelude 2.2L DOHC VTEC I-4 H22A4
Modified by ohiostatez at 2:01 AM 3/10/2005
Turbo intake Filter
Steel downpipe
dquach90
Dec 23, 2010 11:44 AM
