FS/FT: 2002 EP3 Honda Civic Si - Supercharged - MD/DC
$17000
This car is in excellent condition! All new parts are already installed.
38K miles
Satin Silver Metallic
-Hondata K-Pro plus original stock ECU!
-Jackson Racing Supercharger
-Jackson Racing Supercharger Race Upgrade Kit (4.0' pulley - 8psi)
-New 3.8" pulley (10 psi)
-Jackson Racing Stainless Steel Race Header
(Have stock header and 02 Sim also)
-NEW Greddy Evo TT 3" Exhaust
-RC 440 injectors
-NEW D3 Double X Brace!!
-17x7.5 Flat black ATS CompLite Rims
-Comptech Cold Air box
-J's Racing engine damper
-ES Motor Mounts
-Buddy club racing spec white shift ****
-Type R shift boot
-Neuspeed Short Shift adapter
-Aluminum shifter Bushings.
-Wilwood 4-piston big brake kit with forged calipers
-Denso Iridium plugs
-Super Blue ATE high boiling point brake fluid
-Front stainless steel brake lines
-Muteki Lug nuts
-H&R 5mm spacer with extended studs
-VIS Carbon Fiber Hood
(also have stock silver hood)
-Type R carbon fiber wing
-Type R front and rear sway bar 22mm
-Mugen oil cap
-Mugen Rad cap 1.3
-Mugen Fan switch
-Mugen low temp thermostat
-Mugen Aluminum lower control arms with hard bushings !!
-Mugen brake reservoir cover
-HKS earth circle grounding wire kit
-Faze Boost Gauge and A/F ratio gauge with Morping Controller
Gauges are mounted inside custom Radio panel.
Comes with complete stock radio for easy swapping back and forth.
The interior of the car is stock with the exception of the **** and type r boot.
I am not parting anything out.
Email me for more info or pics
Car is located in Maryland between DC and Baltimore.
Modified by sideout2002 at 10:29 PM 3/26/2005
Modified by sideout2002 at 3:10 PM 3/27/2005
Modified by sideout2002 at 4:23 PM 5/19/2005
38K miles
-RC 440 injectors
-ES Motor Mounts
-Type R shift boot
-Muteki Lug nuts
-Mugen oil cap
-Mugen Rad cap 1.3
-Mugen Fan switch
replied to pm
Just in case anyone is military in my area, car is going to be for sale on Fort Meade starting today.
