B16 in CRX AEBS/throttle cable problem-HELP??
Old Mar 9, 2005 | 03:54 PM
Autoworks's Avatar
Default B16 in CRX AEBS/throttle cable problem-HELP??
I am putting together my AEBS intake manifold x/ BBK tb and using my stock B16 throttle cable bracket, but my LS throttle cable and it seems to have entirely to much slack (about 3 inches). Do I need to get a Type R or shorter cable?? Or is there a different cable bracket I need?? Any suggestions?? This is all going on a JDM B16A in my 89 CRX
Old Mar 9, 2005 | 07:29 PM
Autoworks's Avatar
Default Re: B16 in CRX AEBS/throttle cable problem-HELP?? (Autoworks)
bump, anyone?
Old Mar 10, 2005 | 03:45 AM
Autoworks's Avatar
morning bump
Old Apr 14, 2005 | 12:29 PM
DocSean's Avatar
bump for an answer!
Old Apr 14, 2005 | 05:12 PM
rjay8604's Avatar
Default Re: (spankjelly)
you need a type r throttle cable bracket. Also your fuel pressure regulator and intake temp sensor should be having problems clearing each other. If you look at the bracket, does it stick out toward the driver side or the pass side. The type r throttle cable bracket will stick to the driver side.
Old Apr 14, 2005 | 05:17 PM
DocSean's Avatar
It's possible to fab something up fairly easy also, atleast thats my understanding.
Old Apr 14, 2005 | 05:23 PM
rjay8604's Avatar
Yeah actually i made mine for my aebs. Took some aluminum plate from true value, cut, bent, drilled, filed and repeated until i basically replicated the ITR one.
Let me see if i have a pic of it.
DerekHollister
Mar 22, 2016 09:21 AM
k20o2o4civic
Mar 3, 2009 07:22 PM
alscrx
11
Oct 11, 2007 08:26 PM
Autoworks
Mar 10, 2005 04:19 PM
Autoworks
Mar 10, 2005 03:46 AM
