FS: Two turbo ready GSR motors
Will you make something up for me please?
#1 ($3100):
B18C1 with stock bore
SRP 9.0:1 CR
Pauter Rods
Balanced crank
New bearings/gaskets
swirl polished stock valves
3 angle valve job
port matched head
stock valve springs/retainers
GSR cams/gears
GSR valve cover
cut flywheel
(no Intake manifold, injectors, ECU, tranny)
#2 ($3400):
JE 9.0:1 CR
Crower Rods
Balanced crank
3 angle valve job
port matched head
GSR cams/gears
GSR valve cover
cut flywheel
Can have these both by next week
SRP 9.0:1 CR
Pauter Rods
Balanced crank
3 angle valve job
port matched head
GSR cams/gears
GSR valve cover
cut flywheel
#2 ($3400):
JE 9.0:1 CR
Crower Rods
Balanced crank
3 angle valve job
port matched head
GSR cams/gears
GSR valve cover
cut flywheel
Beau Gotti
Dec 12, 2006 08:27 AM
