Just Got: Rear Disc Brakes...I Have Questions. (pics included)
Old Mar 9, 2005 | 02:59 PM
doublethink's Avatar
Default Just Got: Rear Disc Brakes...I Have Questions. (pics included)
Just got these today, they are off a 1994 Integra LS originally.
I have a 1990 CRX DX... My questions are:
1) These bushings look like ***. Are OEM ones expensive, any aftermarket equvilent? (The guy I got these from said often it helps to have a Press to change out bushings, is this true because I dont have one.)
2)Where can i get new calipers and rotors for these, autozone etc or do I need to go to a dealer?
3) These e-brake cables are gonna reach, right?
4) For $150.00 was this a decent deal?
Pics:
Old Mar 9, 2005 | 03:23 PM
bagpipe goatee's Avatar
150's a decent deal, use the lower control arms if you want to have a rear sway bar. some will say that the integra ones are a quarter inch longer than the civic's, therefore affecting toe, but when i put them next to each other they were exactly the same length. only difference was the shock mount was closer to the inside of the car, therefore SLIGHTLY reducing the effectiveness of your spring rates.
as for the bushings, i just saw a site that has the honda part numbers, with a good write up. (i guess i'm going to have to tell you to search, even though you probably know that) Mugen makes those bushings, but they appear to be the same as the redesigned honda bushings.
is your car lowered? because honda had a Technical Service Bulletin saying that those bushings were a poor design and dealers are authorized to replace them for free upon request of the consumer (unless they can find an excuse not to, like a lowered car or something). so, my suggestion, because i'm cheap, is if your car isn't yet lowered, take it into the dealer now, they'll replace the bushings, then pull them out of your old arms and put them in the integra ones when you come home.
Old Mar 9, 2005 | 03:26 PM
shawn_crx's Avatar
Default Re: Just Got: Rear Disc Brakes...I Have Questions. (doublethink)
1. Bushing cost about 50-100
2. calipers/rotor-- >autozone or auto store
3. i have no idea. i'm in the middle of the swap myself. stock e-brake is a pain in the butt to take off.
4. i paid 175 shipped. but I ended up having a extra pair of the donor car.
Old Mar 9, 2005 | 03:27 PM
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">
is your car lowered? because honda had a Technical Service Bulletin saying that those bushings were a poor design and dealers are authorized to replace them for free upon request of the consumer (unless they can find an excuse not to, like a lowered car or something). so, my suggestion, because i'm cheap, is if your car isn't yet lowered, take it into the dealer now, they'll replace the bushings, then pull them out of your old arms and put them in the integra ones when you come home.</TD></TR></TABLE>
my car is not lowered, that is some <u>killer</u> info!!! thanks!
but my question remains, can i swap these bushings with hand tools and no press?
Old Mar 9, 2005 | 03:30 PM
Default Re: Just Got: Rear Disc Brakes...I Have Questions. (shawn_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">
from what ive read the stock crx cables wont make it. and the teg ones are a little long, im sure i can make it work.
anyone know whatever happened to fourthgenhatch.com.... i tried pm-ing him its a shame its down
Old Mar 9, 2005 | 03:31 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: (doublethink)
i have removed and installed new trailing arm bushings without a press, but you will be MUCH better off using a press to install the new bushings.
do a quick search on this for the procedure.
stan
Old Mar 9, 2005 | 07:28 PM
EL Vap133's Avatar
I used CRX si ebarake cables on my 88 crx, worked fine. If you paid $150 for the rear only, you got ripped!! I sell the rear disk brakes for $175 in good condition.
Old Mar 9, 2005 | 07:49 PM
alecjoesph's Avatar
Default Re: Just Got: Rear Disc Brakes...I Have Questions. (EL Vap133)
i bought my full 4x114 conversion from hmotors and only paid 200. and el vap is right use stock crx si cables
Old Mar 9, 2005 | 11:15 PM
ServiceAdvisor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">anyone know whatever happened to fourthgenhatch.com.... i tried pm-ing him its a shame its down</TD></TR></TABLE>
http://gutterslide.com/fourthg....html
Ask and ye shall recieve. He did shut it down for lack of interest and having an extra bill if I'm correct. But somebody was smart enough to mirror the site :D, wish I could give his sn out but I 4got it :/. But credit this link to him. - Darrell
Old Mar 9, 2005 | 11:31 PM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">is your car lowered? because honda had a Technical Service Bulletin saying that those bushings were a poor design and dealers are authorized to replace them for free upon request of the consumer (unless they can find an excuse not to, like a lowered car or something). so, my suggestion, because i'm cheap, is if your car isn't yet lowered, take it into the dealer now, they'll replace the bushings, then pull them out of your old arms and put them in the integra ones when you come home.</TD></TR></TABLE>
are u sure!? b/c i got that click/clunking coming from the rear. if icould have the do that that be killer!
Old Mar 10, 2005 | 07:00 AM
Wes V's Avatar
Default Re: (DieMaster)
Although almost anything is possible. Find a machine shop that has a press and have them press out the old bushings and then press in the new ones!
Wes
Old Mar 10, 2005 | 07:11 AM
EL Vap133's Avatar
Oh and I suggest you use your stock LCAs.
Old Mar 10, 2005 | 07:12 AM
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Although almost anything is possible. Find a machine shop that has a press and have them press out the old bushings and then press in the new ones!
Wes</TD></TR></TABLE>
yea i have a guy that does all my work for me that requires special tools, he doesnt charge an arm and a leg either, i just wanted to know if it was possible to do without, aparently its much more logical to just use a press.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Oh and I suggest you use your stock LCAs. </TD></TR></TABLE>
yes ive read the teg ones will mess with the toe.... hey El Vap, where were you yesterday before i bought these?
its cool bc i paid no shipping, ill just replace the other stuff.
its cool, no biggie.
Old Mar 10, 2005 | 07:15 AM
EL Vap133's Avatar
I was here mang.
Old Mar 10, 2005 | 08:00 AM
Targa250R's Avatar
be professional
Use your stock CRX UCA, LCA, and compensator arms.
Hell, you don't even need the Integra trailing arms. Just bolt the disc hub assemblies to your CRX TAs. If your CRX TA bushings are still good, then all the better.
Turn your calipers in as cores toward some remans at the local auto parts store. You can get rotors anywhere - AutoZone, CarQuest, Honda dealership, etc.
Old Mar 25, 2005 | 10:45 PM
gutted-dx's Avatar
If you do put new bushings in the TA don't use poly because they **** up your suspension some how
Old Mar 25, 2005 | 10:49 PM
EL Vap133's Avatar
Default Re: (gutted-dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">If you do put new bushings in the TA don't use poly because they **** up your suspension some how</TD></TR></TABLE>
Too stiff.
Weel
Suspension & Brakes
May 13, 2010 10:48 AM
truevietluv636
Jul 31, 2007 10:22 AM
potatostix
Suspension & Brakes
Jul 6, 2006 08:36 PM
1fastsi
Sep 9, 2004 06:33 PM
mikecel79
Jun 29, 2002 10:59 AM
